Turbo problem please help
Old May 18, 2008 | 10:24 AM
fcapo's Avatar
Original94
I have a 94 rx7 with 57,000 k on it took it out for a spin everything worked great and then one turbo was only working (by the way I have still stock twins)cheked for vacum leaks seem not to see or hear any can anyone suggest anything please
thanks in advance
fcapo
Old May 18, 2008 | 10:51 AM
Mahjik's Avatar
Mr. Links
Start by working through this troubleshooting guide:
http://www.autosportracetech.com/RX-...leshooting.htm
Old May 18, 2008 | 10:52 AM
silverflash2's Avatar
There's a vacuum box that has two vacuum hoses on it. It's near the top of the engine. Kind of under the strut bar. Near the oil fill. I know if one of those come off, only one turbo will work.
Old Jul 5, 2008 | 06:42 PM
trekmtbr89's Avatar
primary turbo help
New engine - just rebuilt - stock turbos - Car isn't hitting any kind of boost until the secondary turbo kicks in. I'm getting alot of heat in the engine bay (turbo related). engine is operating at normal temps. I've checked through most of the vacuum hose ( all new) everything looks good.
Also getting a fluctuation in the idle which goes away when I tun on a power accessory like headlights. I've heard idle fluctuations are usually the cause of a vacuum leak somewhere. However it's odd that a change in draw from the battery would make this go away.
Old Jul 5, 2008 | 07:44 PM
zack4173's Avatar
Do you have a boost gauge because its kinda hard to troubleshooting boost issues without one.
Old Jul 5, 2008 | 08:09 PM
trekmtbr89's Avatar
yes I do have a boost gauge
Old Jul 6, 2008 | 09:15 AM
trekmtbr89's Avatar
any ideas where I might find a bit more detailed information about how the tubro system works?
Old Jul 6, 2008 | 09:29 AM
Mahjik's Avatar
Mr. Links
Sorry Trek, I merged the wrong thread.
Anyway, take a look at the link I posted above in this thread. It's a troubleshooting guide for the stock twins.
Old Jul 6, 2008 | 10:11 AM
trekmtbr89's Avatar
no problem man, I did find the link and got more than enough info to keep me occupied for the day.
thanks again
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
