Do i need to repalce any gaskets when changing spark plugs?
Old May 15, 2008 | 11:47 AM
When i take off the UIM to change spark plugs ..
do i need to replace any gaskets?
Old May 15, 2008 | 11:57 AM
dgeesaman's Avatar
You don't take off the UIM. In fact I take nothing off the car - I just reach down around the TB elbow and work blind. It's not that hard, and if you go in from underneath it's even easier.
Even if you pull the TB elbow and go in from above it has an o-ring that does not require replacement.
Dave
Old May 15, 2008 | 02:19 PM
Mahjik's Avatar
Mr. Links
(To all the deleted posts) If you aren't going to help, don't post.
Old May 15, 2008 | 03:01 PM
Goukid2's Avatar
I think he meant to say Spark plugs and wires?? if you mean wires than i guess it depends on the condition of your UIM gasket. Last time i checked it was a metal gasket and doesnt really need to be replaced like that. unless yours is leaking.
Old May 15, 2008 | 03:40 PM
Prophet7000's Avatar
VV That's mine VV
Or if the UIM gasket is missing, which is the surprise I had the first time I took the UIM off. If you're just talking about the plugs, just pull the elbow and go to town.
Old May 15, 2008 | 04:13 PM
Six Rotors's Avatar
Bring your car round,I have plugs and will show you how to change them.
Old May 15, 2008 | 05:46 PM
grimple1's Avatar
Turd Ferguson
http://www.rx7.org/Robinette/sparkplug_wires.htm
he's probably calling the long plastic IC piping off the TB UIM.
Old May 15, 2008 | 06:09 PM
dgeesaman's Avatar
If you're also changing wires the job gets a lot bigger.
IIRC there is so little room around the coils that I removed the TB and could barely do it. The plug wires are definitely easier when the UIM is off, then you can plug the wires into the coils without as much stuff in the way.
Dave
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
sYnth.
Aug 19, 2015 06:27 PM
