Haltech Map sensor vacuum source.
Old May 13, 2008 | 05:56 PM
13B-RX3's Avatar
7s before paint!!!
I have a carbed style intake and i need to add a vacuum port. I am running a high overlap port so the vacuum signal will be weak and fluctuate. Would it be a good idea to tap into both primary runners to try and get a more stable signal?
TIA
Allen
Old May 13, 2008 | 06:10 PM
C. Ludwig's Avatar
www.lms-efi.com
I've done that on an ITB setup. Run two nipples to a T then to the MAP sensor. Worked well enough that I didn't have to fool with TPS blend or zero throttle mapping. It's worth a try anyway. If that doesn't work the zero throttle map should get it done for ya.
Old May 13, 2008 | 06:13 PM
13B-RX3's Avatar
7s before paint!!!
Sweet, thanks for the info.
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
befarrer
Sep 4, 2015 08:26 PM
Frisky Arab
Sep 4, 2015 06:17 PM
