Car Wont start....HELP!
Old May 11, 2008 | 01:48 PM
hawaiianrx7's Avatar
my FD was starting fine, and one morning out of no where it just didint start. i go to turn the key and nothing happens. the car wont turn, and only the lights inside come on. can some one help me please.
Old May 11, 2008 | 02:44 PM
4CN A1R's Avatar
sleeper
have you tried push starting it? it could be flooded
Old May 11, 2008 | 04:25 PM
Rollogic's Avatar
Easiest thing to check 1st is your fuses, under the steering column and under the hood.
Old May 11, 2008 | 06:10 PM
aicrotary2's Avatar
check the clutch pedal plug they tend to rott out from age. look on the carpet under the pedal for peices of the plug
Old May 11, 2008 | 06:30 PM
Sgtblue's Avatar
Urban Combat Vet
Actually, given the symtoms described, the easiest thing to check is the battery terminals. Make sure they're clean and tight.
Old May 11, 2008 | 08:43 PM
i looked for the fuses under the steering column and the only one i saw that related was ENGINE and it was fine. i looked for for clutch plug pieces and i couldn't find any. my battery terminals looked bad so i cleaned them off and still wont start.
anymore ideas?
Old May 11, 2008 | 08:56 PM
AzEKnightz's Avatar
can u ensure that the battery is actually charged? Also, when you tried cranking the car, for like few seconds, and touch the terminals on the battery. If you feel that it's hot, that means the battery is trying really hard with alot of resistances. Make sure your battery have sufficient voltage/amperage to start the car... Go with basic diagnostic first. Fuel, Spark/timing, and Air.
Monsterbox
Jul 29, 2022 10:48 PM
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
