wheel diameter
Old Apr 29, 2002 | 02:19 PM
GTUsGUY's Avatar
wheel diameter
which is the diameter of the original steering wheel? Is that I'm going to order a wheel trough the net and I can't measure it right know. This because my car is almost 3,000 miles from where I'm right know.
Is it 330 mm or 350 mm?
Old Apr 29, 2002 | 04:23 PM
NZConvertible's Avatar
I'm a boost creep...
I’m not sure what the measurement is, but do not get anything much smaller than the original. My Momo is only fractionally smaller than stock outside, but because of the thicker rim, the inside diameter is quite a bit smaller, and it blocks the top of the speedo and tach, the indicators, the oil pressure gauge and my carefully positioned aftermarket boost gauge!
Old Apr 29, 2002 | 11:04 PM
RETed's Avatar
380mm but it's offset upwards by 2mm.
No aftermarket steering I know of is of this EXACT dimensions.
-Ted
Old Apr 30, 2002 | 05:51 PM
GTUsGUY's Avatar
thanks ted
nzcovertible, do you know the exact diameter of your MOMO steering wheel?
Old Apr 30, 2002 | 05:56 PM
GTUsGUY's Avatar
ted, will a 350 mm feel to different?
I'm planning on buying a 350 mm with the "D" shape
Old Apr 30, 2002 | 11:22 PM
RETed's Avatar
Going with a 350mm is fine...&nbsp I run a MOMO Race 350mm right now.&nbsp I have no PS, and it feels a lot better, IMO.&nbsp I find 320mm or smaller TOO small for a non-PS FC.&nbsp If you're on the taller side (over 5'10"), the smaller diameter wheel tends to block the top edge of the instrument cluster, which is slightly annoying - you can't see the blinker lights. A steering column spacer works real well with the 350mm wheel!
-Ted
Old May 1, 2002 | 09:40 AM
GTUsGUY's Avatar
thanks again
rx7jocke
72
Jun 17, 2016 03:48 AM
