why rx7 intercoolers cost so much?
Old May 1, 2008 | 01:23 PM
initial D is REAL!'s Avatar
Im jsut curious why the fc and fd intercooler kits cost so much. I understand the cores might be a little bigger and takea few more bends, but why are 240sx/silvia intercooler kits going for 550 retail while rx7 ones retail above $1000?
I bought my car from a friend that had already put a greddy fmic for my t2. It doesnt even come with a bov flange and its made as if the brake mc is on the other side.
It just seems like a big jump in price. Who's making good intercooler cores, it might even be cheaper to go to a custom fabrication shop to custimize one for your application.
Old May 1, 2008 | 01:39 PM
astrochild7's Avatar
controlled kaos
supply and demand..... you prolly have a right hand drive intercooler setup..
Old May 1, 2008 | 06:38 PM
I didnt know greddy made one for rhd and lhd. From what I know everyone else had the same problem
Old May 2, 2008 | 09:04 AM
turbine's Avatar
the greddy kit is RHD, i have it and it works fine. i dont think they come any other way. you just have to shorten it a bit.
Old May 2, 2008 | 04:28 PM
Yeah, I ended up cutting a little bit off mine too. Too bad I dont have a piping beader. Because of cutting it I need a slightly longer silicone coupler. Mine barely fits at the edges, its a little scary. Also, the transition hoses are cheap, they crack. For the price of this intercooler i would expectsilicone transition couplers. Also the mounting for the intercooler is solid to the radiator support. It would b nice if a company had a rubber bushing to allow some chasis flex. My intercooler cracked at the top and needs to be rewelded.
Everything works ok, but I would expect more for something that retails over 1000
Old May 2, 2008 | 05:05 PM
here is the pic of the damage
I finally pigured how to post pics!!!
Old May 2, 2008 | 07:31 PM
silverTRD's Avatar
Time or Money, Pick one
wow, that sux man
Old May 2, 2008 | 10:44 PM
turbine's Avatar
wow, maybe you got a bad one. i flog the **** out my car and i even crashed it a few times and my **** didnt break it bent. lol
Old May 3, 2008 | 01:47 PM
Well, I figure most oem intercoolers would b mounted with rubber bushings to allow some give. I bought my car from a friend that had bought the fmic already.
I just had to cut the intake pipe shorter to clear the brake MC, change out the transition couplers to silicone ones, and weld on a bov flange. Ive seen these kits retail over 1000. For the price I would expect a BOV flange, rubber mounts, and silicone transition couplers.
If I had to start all over again, I could make my own custom fmic kit
Old May 3, 2008 | 02:12 PM
silverTRD's Avatar
if you are in pasadena, ca. i am an hour away, i know a guy that can fix it pretty cheap. pm me if you like.
Old May 6, 2008 | 01:45 PM
Sarusanj's Avatar
QM
Veteran: Navy
Veteran: Reserves
Wow. I've had 3 Greddy front mount kits and never had anything like that happen.
Old May 7, 2008 | 12:58 AM
Thanks for the offer. I can tig weld myself, but I dont have a tig welder in my garage. I'll either go to my old work , or use the school's welder. Good looking out. Thanks
Its more my fault, but still I would like a rubber mount or something to allow more flex. Especially for the price of these intercoolers
When I used to have a 240sx I noticed greddy kits being about 500 retail. Im just wondering why greddy charges more than double retail of the silvia FMIC kits
thecody59
40
Aug 23, 2015 06:41 PM
