How hard is it to swap in a gsl-se front suspension and rear axle into a 82 gs
Old Apr 28, 2002 | 05:57 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I am trying to get wheels and it is turning out to be a pain in the ***.
I was thinking of trying to swap in a gsl-se front suspension. how hard is it.
Old Apr 28, 2002 | 06:30 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Its harder to find one than to do. ITS A DIRECT SWAP Easy
Old Apr 28, 2002 | 06:39 PM
I am guessing i will need things like a gsl se brake cylinder.
Old Apr 28, 2002 | 07:24 PM
Directfreak's Avatar
I am a Jeeper Now.
nope.
Old Apr 28, 2002 | 07:49 PM
I know I'll get the 4x114.3, will i get the 40 mm offset also.
The rear axle swap part seems simple but what are all the parts I need for the front.
Shocks/springs
spindle
control arms ect.
Old Apr 28, 2002 | 08:01 PM
Max7's Avatar
Admitted Sevenaholic
The front is just a whole strut/spindle/spring swap, you can use the control arms you already have.
you get the lug pattern AND offset.
Old Apr 28, 2002 | 08:48 PM
thanx, sounds better than custom drilled and spacers.
I am going with tokico springs/shocks while Im at it.
Is there a artical somewhere which explains this swap.
Old Apr 28, 2002 | 08:52 PM
MIKE-P-28's Avatar
Now I didnt know that, so just 2 bolts on the bottom and use my old good control arms? Got new ball joints in them. Thats freaking easy!
And sad thing is I just put new wheel bearings in there...
Right side rotor is new too
Old Apr 28, 2002 | 09:56 PM
V8kilr's Avatar
im doing the swap right now,
only have the back in so far,
im gonna post a huge article on it,
probably put it on my site since the ****** moderators dont like to put **** in the archives.
Old Apr 29, 2002 | 09:46 AM
now i just got to find a se in a junk yard.
Old Apr 29, 2002 | 09:51 AM
79+80_rx-7's Avatar
I know, RIGHT!!!!! Its BS!
Old Apr 29, 2002 | 09:55 AM
Are any of the brake fittings different.
Old Apr 29, 2002 | 10:13 AM
MIKE-P-28's Avatar
If you swapping a -SE susp into a SA. You will have different brake line pitch. If its a 81-85 FB , and swapping in a -SE, it will be a direct swap!
matty
Jan 18, 2020 10:39 AM
GrossPolluter
Aug 15, 2015 10:32 PM
