SuperPro Performance Suspension Bushings for FD,FC,FB!!!
Old Apr 29, 2008 | 01:24 PM
JKL Racing Engineering's Avatar
We are proud to announce that we are now distributing Superpro Performance Suspension Bushing Kit. We will be offering SuperPro Bushing kits for FB, FC, and FD.
This kit includes total 24 bushings:
Descriptions--------Quantity
1. diff.......................2
2. toe links................4
3. trailing arms...........2
4. shock mounts.........2
5. rear upper arms.......4
6. front arms..............8
7. steering rack...........2
We also accept orders on individual bushings, so feel free to contact us.
Descriptions and Introductions on SuperPro Performance Bushing Kit:
The Polyurethane that is specifically blended for the SuperPro product has mechanical properties that make is extremely successful in its application. The properties of extreme resistance to abrasion, low compression set, high tear strenth and a resistance to oils and solvents make it ideal fo automotive applications. These properties lead to a resilient product that is highly versatile in its applications.
The crush tubing is an integral component of the suspension bushing system and is necessary for free pivoting. The crush tubes are made to precision tolerances to ensure that the precise fits are maintained. All SuperPro tubes are made of STEEL & ZINC plated for corrosion protection and appearance. In some applications SuperPro incorporates end knurls and hardened tubes to provide positive location. As required SuperPro provides presion machined steel SHELLS to allow the installer to quickly and easily replace worn components.
When polyurethane is used to replace rubber in many suspension applications, it often has to accommodate large variances in tolerances.
Rubber is not a precision component and will compress or distort readily to allow fitment, which in turn creates binding of the bushings. This is one of the main reasons why SuperPro polyurethane is superior to rubber bushings, as they have a free pivoting point and not a torsion pivot like rubber. SuperPro had to develop a method of achieving the correct pre-loads while still accommodating a range of variances in sizes. Bullet grooves allow the bushings to flex and accept a much wider range of sizes while still maintaining free pivoting of the bushings.
We have a limited quantity in stock right now and ready to ship. We offer discounted WorldWide shipping rates. We also offer SuperPro Bushing Kits for other rotary cars (RX2, RX3, RX4, etc.) so please don't hesitate to contact us for your special orders.
Prices/Payment Instructions:
Please include your RX7Club forum username during paypal process and please post here with the exact username account to verify the sending of payments.
Full FD3S SuperPro Adjustable Suspension Kit: (Shipping will be $19 Fully Insured)
$500 (local pick up)
$505 (paypal e-check) = $524.00
$500 + 3% paypal fee (all other paypal payments) = $534.57
We also offer the following individual SuperPro Suspension Bushings: (Limited quantity in stock, please contact us for pricing)
1. Rear Upper Arms
2. Rear Differential
3. Rear Shock Absorber
4. Rear Toe Control Arms
5. Rear Trailing Arms
6. Front Steering Rack
We offer customized Superpro Bushing Kits tailored to each individual customer's needs. Please email JKL Racing Engineering at sales@jklre.com for specific pricing.
Old Jul 3, 2008 | 05:43 PM
Bob H's Avatar
Veteran: Navy
Payment was sent per e-mail, no response yet, please acknowledge reciept and shipment.
Thanks!
-Bob
Old Jul 4, 2008 | 02:30 PM
Andrew.'s Avatar
The end of an era
Are these still available, ready to ship? I'm looking to get a set for my FD...
Old Jul 6, 2008 | 01:35 PM
Yes, we still have several kits left in stock so act fast if you want it.
Old Aug 4, 2008 | 03:33 AM
speedfactor415's Avatar
I'm interested in a full set of bushings for my FD...i am also local and can just pick them up..PM me with contact info if you can thanks..
Old Aug 4, 2008 | 01:32 PM
Just pmed you. Thanks!
Old Aug 10, 2008 | 05:19 PM
Bob H's Avatar
Veteran: Navy
Bringing this back to the top. Kevin - I sent an e-mail concerning missing bushings(the trailing arm bushing).
A note to anyone considering this kit - the kit is supposed to be the adjustable version - and has the upper rear control arms w/an excentric bushing center. There will be absolutely NO WAY to adjust this once you install it - it is a press fit, and you need to be sure of which direction you istall them. With the hole on the bottom, the arm sits a little higher, on the top, lower - w/minimal change to alignment settings. If you install the bolt hole center to the inside or outside, you are now changing camber or toe - camber if they are both installed in the exact same position - toe if there is any change from a pure 90 degree position.
Be informed. I did not catch the problem until I was ready to install them. I'm installing mine in a pure vertical orientation to minimize their impact, but it will have to be compensated via the toe link and the camber bolt on the bottom.
-Bob
Old Aug 10, 2008 | 10:08 PM
Bob H's Avatar
Veteran: Navy
Update on that bushing from JKL Racing:
For the SPF2679K, SuperPro purposely designed it to have an eccentric crush tube for providing the ability to adjust the camber without the use of a camber adjusting bolt. The crush tube has an offset hole, so once the bolt goes through you can rotate it inwards and outwards by simply loosening it and pulling/pushing the tire. Its the same principle as the camber adjusting bolts that you would just turn, except the offset belongs to the crush tube instead of the bolt.
My understanding - which I'll be able to verify upon the finished install - is that the crush tubes,(centers), don't freely move. Based on what is above, it sounds like they move around.
Old Aug 11, 2008 | 11:18 AM
The SuperPro adjustable kit is at least $20 more expensive than the non-adjustable kit that the other individual used to sell on the forum. We are basically throwing the adjustable kit in at an even lower price than the non-adjustable.
yep, you should be able to rotate it by loosening it and maneuvering the tire. Honestly, don't worry, we sold plenty of these adjustable bushings to all over the world and I believe that SuperPro sold way more, so it will work.
Let us know if you got any more questions!
Old Aug 18, 2008 | 01:28 AM
TENAZ's Avatar
ROTARY SCAMBUSTER
CA SuperPro Performance Suspension Bushings for FD,FC,FB!!!
I'm looking suspension bushing set for my FD
Does the set includes the OEM rear bushings ?
Hw much it does cost shipped to Ca 91311 ?
Tks
Tenaz
Old Aug 18, 2008 | 11:23 AM
No, SuperPro kit does not include the pillowball bushings.
The shipping charge is included in the prices listed above in the first post.
We only have one full kit left reserved for a local buyer. If he does not pick it up within this week, this will be up for grabs.
Old Aug 24, 2008 | 05:52 PM
sanchezrx-7's Avatar
pm sent for pricing on fc kit
Old Nov 4, 2008 | 08:09 PM
did you get anymore of these in stock?
Old Nov 5, 2008 | 08:19 AM
felix_is_alive's Avatar
IS this still available? i am interested , but cannot get any contact with anybody
Old Nov 8, 2008 | 02:03 AM
RE-Renegade's Avatar
PM me the discount code! i'm very interested in getting these bushings for my FD.
Old Dec 20, 2008 | 05:55 PM
rotary-x's Avatar
I am interested too.
Old Jan 2, 2009 | 01:54 PM
Can you still get these? Very interested but the web site says "Sold Out"
Old Jan 9, 2009 | 06:27 AM
any new developments here ???...site still says sold out , no e-mail response ....i need these bushings bad
Old Jan 12, 2009 | 04:05 PM
these things seem to be harder to get then gold
Old Mar 25, 2009 | 03:56 PM
DeeSan's Avatar
Sexy Boo
why the **** is it that hard to find aftermarket bushings for our rx-7's ?
Old Apr 17, 2009 | 01:35 AM
We have been thinking about replacing the SuperPro products with an alternative and much easier to source suspension bushings product line. The quality and performance will be similar to SuperPro level, just checking to see if there are still enough interest in this type of products for us to even bring them in. So show your interest here if you need some quality suspension bushings other than the hard to get SuperPro.
Old Apr 17, 2009 | 11:42 AM
DeeSan's Avatar
Sexy Boo
still interested! Could you post some info on the other bushings your talking about please?
Old Apr 17, 2009 | 07:47 PM
Force13B's Avatar
No more G6
Interested!
Old Apr 17, 2009 | 08:27 PM
Specter328's Avatar
NASA TTS Build
interested
Old Apr 21, 2009 | 01:56 PM
Alright, seems like some positive interest, we are setting up the distribution right now with the company and will release the info once the deal is settled. So check back here or on our online store in the near future, we will have something for you soon!
