Noise in rear coilover...
Old Apr 28, 2008 | 03:13 PM
Brismo7's Avatar
6 Speed FC
i have a squeaking/cricket type noise coming from my rear passenger side coilover. anyone have any ideas? I'm thinking a rubber isolator between the chassis and top of the coilover might solve this? anyone know where i might be able to get two (one for each side?)
Or does anyone know what might be causing this?
1988 FC BTW
Old Apr 29, 2008 | 01:56 AM
Brismo7's Avatar
6 Speed FC
nothing?
Old Apr 29, 2008 | 10:06 AM
cewrx7r1's Avatar
Eye In The Sky
Go try lubing it, be inventive!
Old Apr 29, 2008 | 12:14 PM
ptrhahn's Avatar
Are you absolutely positive it's the coilover? Could also be the rear sway bar bushing, particularly if it's a urathane upgrade. I lubed mine w/ CV joint grease.
Old May 1, 2008 | 03:21 AM
Brismo7's Avatar
6 Speed FC
i have the stock sway bar bushings in the rear. and it sounds like its coming from inside the cabin. Thanks for the tip Cewrx7r1. i will try some type of bushing lubrication. i bet that will help.
Old Jun 1, 2008 | 05:46 PM
dragonxbreath's Avatar
hey sorry to repost on this...but my coilover makes a rubbing sound as i compress it up and down. even when i took the wheel off and pressed up on it it did the same. and when i roll the car back and forth it seems it makes the same noise. so what could this be?
Old Jun 1, 2008 | 05:49 PM
there is also a lot of play in the coil when i jack it up. i mean i can move this thing up and down a inch or so...so is this normal
Old Aug 25, 2008 | 05:02 AM
0verb00st's Avatar
sounds blown...
msilvia
28
Apr 14, 2016 12:58 PM
20B Forum
Aug 30, 2015 12:08 AM
Michael Mansour
Aug 18, 2015 03:13 AM
