Cooling mist - Clog detector valve?
Old Apr 27, 2008 | 01:28 AM
Dan_s_young's Avatar
Turbo widebody FB
Hey guys,
Just bought my cooling mist kit a little while ago and have it mostly hooked up now. Just have one question. This valve setup was supplied with the kit just want to make sure I hook it up properly. Is this a clog detector? The instructions don't show anything pictured like this. It has connections for normally open, normally closed and a common. But doesn't describe how it needs to be hooked up.
Any help is appreciated, thank you!
Old Apr 27, 2008 | 10:05 AM
Turbo widebody FB
Read a bit closer in my supplied instructions and I found the information I needed. Looks like I just hook up a LED with 12V to one side and hook the other side to the NO port, and ground the COM port.
Old Apr 27, 2008 | 12:47 PM
coolingmist's Avatar
Correct. It will light up when the system injects. Once the system stops injecting the light will go out. If its ever litup when you are not in boost, you either have a clog OR the system is injecting.
CM
Old Apr 27, 2008 | 12:57 PM
Turbo widebody FB
Excellent, thank you for confirming!
Old Apr 28, 2008 | 07:39 PM
Turblown's Avatar
Turn up the boost
Make sure it has a good ground or it will act funny.
Rotary Performance Parts
ls1swap
Jun 3, 2024 03:25 PM
scissorhands
Oct 8, 2015 01:17 PM
Rotafuzz
Sep 30, 2015 09:55 AM
