(FUEL) How To: Diagnose your fuel return line check valve
Old Apr 26, 2008 | 09:00 PM
Experiment.Seven's Avatar
Rota-lution
If you're experiencing any type of acceleration loss/bogging/hesitation. Check your Return Line Check Valve!!!
Also, don't run a 10 micron fuel filter unless you have a pristine tank. It captures dirt like wildfire.
Just my .02.
Happy Rotoring.
Old Apr 27, 2008 | 06:00 AM
bliffle's Avatar
Where is that check valve? How can we identify it?
Old Apr 27, 2008 | 08:33 AM
mazdaverx713b's Avatar
Have RX-7, will restore
the check valve is located in the engine bay on the return line. its aluminum.
Old Apr 27, 2008 | 12:42 PM
DarkDrakeX's Avatar
RX-7 NUT
Okay so i found it and i blew it out with my air compressor. I was gonan buy a new one from az for the hell of it cuz it doesent look too expensive but they said its a dealer only item. When i blew in one way no air came out the other end.. and when i blew in the other way air came out but so did alot of dust particles. also it had white dust particles around the things that go inside the tubes. Is it okayz/? or shoudl i buy another one.
Old Apr 27, 2008 | 12:55 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
It is a one way check valve, it is supposed to only flow in one direction (to the tank, not to the carb). MAKE SURE you install it the correct way! All the chunks you blew out of it is a good thing, now it can do its job better.
Old Apr 27, 2008 | 02:52 PM
Rota-lution
Check Valve
This is what it looks like.
the airflow goes from right to left according to this picture. The side with the indentation is the one coming FROM the carb.
Attached Thumbnails (FUEL) How To: Diagnose your fuel return line check valve-check-valve.jpg
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
