new to rotary
Old Apr 25, 2008 | 11:22 PM
n3cron99's Avatar
Newbie
new to rotary
Hello all. I have just purchased my first rotary engined car, a 1985 RX7
I will be doing quite a bit of research so you my see me around here and there. I dont post much but ill will be around. Just wanted stop in and say hi. - Max
Old Apr 25, 2008 | 11:32 PM
rotary84's Avatar
welcome do you have pics of ur 85 also wat model??? gsl , gsl-se??
Old Apr 25, 2008 | 11:49 PM
axle's Avatar
good luck with you car the guys hear will usually try to help if you need it to so don't be to shy welcome to the forum also let us know about any mods and +1 on pics also you might wan't to register your car on the site
Old Apr 26, 2008 | 11:15 AM
n3cron99's Avatar
Newbie
sry no pic as of yet. its a GSL
well I don't know much about these cars but the guy who i bought it from said it had the following mods:
Engine was ported(is there any way to confirm without opening it up?)
Webber carb (also handed me a bag with parts and said it was all the emissions stuff he had taken off)
stage 2 clutch
and that the exhaust was open from the headers back to the muffler no silencer (I'm guessing this goes where the cats used to be) its freaking loud
things that are wrong:
drivers side window suck down(gonna check this weekend if off track or motor)
passenger side front fender needs to be replaced
my favorite quick fix, the bike brake cable for a throttle cable (he said he couldent find a universal cable after the Webber install)
other than that the car is very solid,interior is good exept for the drivers seat which has a few tears in it. carpet good ,dash good no cracks. all in all not bad.
EDIT:also he said it was lowered but ill have to check against the stock ride hight -
Old Apr 26, 2008 | 01:16 PM
rxtasy3's Avatar
welcome to the club. ur local drag strip might be a way to tell if it's ported, or u could pull the intake and look at the ports but u'd need stock port irons to compair it to. a quick search of the net brought this: http://www.carforums.net/showthread.php?t=10251. the power window issue could also be the switch, unless it went down with no problem but just wont go back up. then yes it's most likely the motor. try some lubrication first tho. also be sure to check out the faq's and if u don't have one, get or download a copy of the fsm.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
