Please help diagnose this problem, i need an answer
Old Apr 28, 2002 | 04:57 AM
My car revs up too quickly with partial throttle, to the point where if i hold the partial throttle the revs keep on rising. It feels that the throttle has become so sensitive that when i touch the pedal the car revs up and keeps on revving with steady and very light pressure on the gas pedal. What is wrong with my car??? the engine running at a much higher rpm with very little pressure on the gas pedal in each gear? any solutions?
Old Apr 28, 2002 | 06:42 AM
Rated R1's Avatar
Oji San
Try adjusting the throttle cable. There are some adjustment nuts on the UIM to do this.
Old Apr 28, 2002 | 10:14 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Do you have an aftermarket ecu?
Old Apr 28, 2002 | 02:21 PM
I dont have an aftermarket ecu, are the throttle adjustment nuts right where the intake manifold is?
Old Apr 28, 2002 | 02:26 PM
purepsi's Avatar
maybe a slipping clutch???
Old Apr 28, 2002 | 04:33 PM
amp's Avatar
amp
old yella
..if the car is not accelerating relative to the rising rpms...your clutch is slipping
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
The1Sun
Sep 18, 2015 07:13 PM
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
invinciblejets
Sep 13, 2015 08:22 AM
