please help
Old Apr 23, 2008 | 04:21 PM
texas_rx7's Avatar
please help
Ok just replaced the pulsation damper on my FC because it was leeking gas. But I still smell it,any ideas please help. Sorry if this question has been asked before im new to this.
Old Apr 23, 2008 | 04:45 PM
AbortRetryFail's Avatar
Trunks are for corpses.
Go back over all your fuel line connections and double check for leaks. Did you replace the hoses too while you were under there?
Old Apr 23, 2008 | 04:49 PM
texas_rx7's Avatar
no didnt no better,like i said im new to the 7s need all the help i can get thanks
Old Apr 23, 2008 | 05:39 PM
socalrotor's Avatar
when you swap out ANY copper washer a new one is needed. The washer is a crush type washer that is only good for one tightening. There is one on each side of the FPD. It might not be the source of the leak, but it is good info to share with ya.
Old Apr 23, 2008 | 08:59 PM
dazed01's Avatar
I
Maybe your injectors are leaking now. Did you put new orings on them? Might as well pull the manifold again put new orings on the injectors and replace teh fuel lines and vaccum lines. While you're at it clean off the 6pi sleeves lol Anything I miss?
Old Apr 23, 2008 | 10:06 PM
socalrotor's Avatar
Originally Posted by dazed01
Anything I miss?
Clean up the big ground lug under the manifold?
Old Apr 24, 2008 | 08:13 AM
texas_rx7's Avatar
thanks for the info guys
Old Apr 24, 2008 | 08:21 AM
Red_Rabbit86's Avatar
new to the rotary world
did you clean your cross member or area around it, it could just be soaked with gas and grese
Old Apr 24, 2008 | 08:53 AM
texas_rx7's Avatar
no i didnt but ill check it out thanks.Thinking about taking it to a mazda shop so they can tell me whats wrong with yes or no?
Old Apr 24, 2008 | 09:21 AM
Aaron Cake's Avatar
Engine, Not Motor
Jump the fuel pump test connector (yellow two prong plug under the airbox) and turn the key to "RUN". This will allow the fuel pump to run while the engine does not. Check the fuel system for leaks.
Old Apr 24, 2008 | 10:24 AM
texas_rx7's Avatar
ok thanks ill try that any thing else?
Old Apr 24, 2008 | 04:52 PM
hanman's Avatar
One of the things I usually do, especially if I have to take everything off the top of the engine, is to pull the injectors and have them cleaned/rebuilt. While I am in there, I replace all three rubber pieces on the injectors, replace the fuel lines, and replace the vacuum lines. Before I put the throttle body and everything else back on, I test the primary injectors for leaks, by pressurizing the system, as Aaron states above. Once I get the secondaries on, I do the same thing again.
I like doing everything at once while I am in there, cause it's a pain to have to go back in to fix a leak or whatever.
Old Apr 24, 2008 | 04:55 PM
KillaKitiie's Avatar
Bongolio
When i installed a banjo bolt in my old S4 this caused me a fuel leak..I never thought that after loosening those washers that they change size. I would second this notion!
