my new engine video attached. Bad gas milage -10 vaccume
Old Apr 22, 2008 | 11:28 PM
chrisw80's Avatar
Wink my new engine video attached. Bad gas milage -10 vaccume
video of my engine click the link below to view it. Its a brand new atkins rebiuld w/ 3mm seals. but im only seeing -10 vaccume and im geting like 10 miles to the gallon. what do u guys think.
http://www.youtube.com/overboosted7
Old Apr 22, 2008 | 11:33 PM
nycmexican77's Avatar
NY nice
what pulley set up u have?
Old Apr 23, 2008 | 12:04 AM
evileagle's Avatar
Reverse Cerberus
How "brand new" is it?
Old Apr 23, 2008 | 12:18 AM
chrisw80's Avatar
Arrow
i was told it's an s4 block brand new everything rotors housings irons everything new other than the eshaft. However ever when worm i see apx 13-14 -vac i dont know man.
Old Apr 23, 2008 | 12:21 AM
turboIIrotary's Avatar
how many miles?
Nismo Convert86's Avatar
400WHP or bust
Things need break in time, my used part rebuild (other than all new seals) had 12inhg at idle, now it makes 18-20 at idle, it idles around 750-850rpm. Just give it time, and the pulley set up is a Gilmer drive.
Old Apr 23, 2008 | 12:58 AM
lastphaseofthis's Avatar
My job is to blow **** up
whats the Scale for Vacuum? what indicated a good engine and bad.
i know my rebuild got 175 miles for its first tank, then it went to like 220, and now i see 270-280per tank, and thats a turbo and i get on it alot....
Old Apr 23, 2008 | 01:19 AM
chrisw80's Avatar
Talking
ok, well how do u get that good of milage its costing me like 20 bucks a day to to drive like 5 miles back and forth from work, well and i think vaccume might increst becasuse i see like -10 vac at idle cold and like 13-14 worm after its wormed up and ive goten on boost a few times. hmmk. Yes its a gilmer drive pully set u can get them at www.tweakit.com and they have to be shiped from austraila and there super spendy but worth every penny i keep geting asked if i have a supercharger under the hood :-) ok well anyways i have apx just over 2k miles on my engine runs super strong never died on me its flooded 2x's and its always started right back up. I babbyed the engine (noboost) for the 1st 1200 miles. how long untill its broken in there atkins seals and ive herd atkins seals seat fast.
Old Apr 23, 2008 | 03:08 AM
eriksseven's Avatar
Make Money.
Should be basically broken in at 2000 miles... I've gotta say, you really suck at spelling man. No offense, but I just had to say it.
Either way, I'm guessing series 4, 8.5:1 rotors and it's street-ported? Either way, those vac. numbers (warm) aren't that bad. You should at least compression test the engine to know if there's a problem or not.
Old Apr 23, 2008 | 03:53 AM
RX7 13B 4 UR AZZ's Avatar
love the pullies you are probably running rich at idle.
Old Apr 23, 2008 | 05:18 AM
RETed's Avatar
Stock ECU?
Is the O2 sensor working and plugged in?
-Ted
Old Apr 23, 2008 | 09:27 AM
chrisw80's Avatar
Talking
yes the stock o2 sensor is plued in and working. and im using a rtek ecu 1.7 with 750 secondarys
smikels
Aug 18, 2015 01:26 PM
