headlight switch headache
Old Apr 20, 2008 | 09:59 PM
Idrinkalot's Avatar
of Propel
ok so a couple weeks ago i replaced my headlight switch. Before I plugged it in I noticed that one of the metal plugs on the harness was fried....I plugged the switch in anyway and checked the tail lights. They worked so I went about my business and didn't worry about the fried harness since everything seemed to be ok. Then last night my gauge lights weren't working again...bad sign. I checked the tail lights and they weren't working either. I have a feeling the harness is the problem and I hope it is, but is there a possibility that there could be some other kind of electrical problem coming from somewhere??
Old Apr 20, 2008 | 10:35 PM
tommys's Avatar
Mellow Yellow
Mine did the same thing...replaced harness with one from S5 and now turn signals do not work...waiting to get S4 one now..
Old Apr 20, 2008 | 11:14 PM
Icemark's Avatar
You must replace the light switch harness as well as the light switch if either has fried. If you don't you will continue to burn through switches.
Old Apr 21, 2008 | 05:00 PM
Idrinkalot's Avatar
of Propel
yeah that's what i was afraid of....the switch was a pain install and the harness looks even tougher....can i pull out the old harness underneath the dash or do I have to pull off the face of the dash to get to it?
And also....will a wiring harness for an s4 even work on my s5?
Old Apr 21, 2008 | 10:37 PM
Icemark's Avatar
The harness is about 20 inches long, and plugs into the blue plug next too the power steering computer.
No... you must use the same series light switch harness as the turn signal switch. So if you have a S5 turn signal switch (and gauge surround) you must use a S5 light switch harness.
Old Apr 23, 2008 | 02:46 AM
Idrinkalot's Avatar
of Propel
Thanks for the help Iceman. I bought the Haynes repair manual and it's pretty specific, exept for what I need to get done. Every time.
betes
Sep 27, 2015 08:25 AM
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
