Wet Sanding Tail Lights - Good idea? How?
Old Apr 20, 2008 | 05:36 PM
dhahlen's Avatar
FD Under Construction =P
Have some scratches in my tail lights that I want to get rid of.... I found this on some random forum... wondering what you guys think or if anyone has done it before?
Get some 1000, 1500, and 2000 grit sanding paper... you can also get 3000, but 2000 should be fine. Also get some Plast-X by meguiars. Wet sand it with soap/water mixture starting with the 1000 and sand it till you can't feel too much of the scratch. Then dry it off. Should look really cloudy like you just screwed up. Then move on to the 1500 in the opposite direction. (if you were sanding vertically, now do it horizontally) Once again let it dry and sand with the 2000 the same direction as the 1000. Do the same if you decide to get 3000 too, but you shouldn't need it. Once sanding is done it should all feel really smooth. No get a microfiber cloth and put some Plast-X on the towel and in a circular motion apply the paste. Use pressure, but not too much as you can break the taillight. Do it a couple of time... till you get what you want. Once you are happy; put some of the paste on the taillight and with your fingers give it another "waxing." Then just add some quick detailer spray on it and call it a day.
Some notes:
- Let your sanding paper get really wet, so soak it for a couple minutes (like 7)
- Use new water/soap for each grit.
It'll come out better than new... seriously. I did this to my tails and bumper lights and the 3rd brake light.... what a difference! Hope this helps man!
Opinions? Suggestions?
Thanks
Old Apr 20, 2008 | 06:26 PM
grimple1's Avatar
Turd Ferguson
I've seen it done on other cars. the best advise I could give you is to try it on a small area first before you do the whole lighting assembly.
Old Apr 20, 2008 | 06:28 PM
Davin's Avatar
Back door, no babies...
Veteran: Navy
i would not do it devil dog :/
Old Apr 20, 2008 | 06:29 PM
Mybaby's Avatar
NY ok but
it is a good idea but what seried\what year of taillights. I have a 95 which for some reason came with the standard block tailights but with faint circles. when i took them apart they had raise circled on the face of the lens. only trying to insert some useful interesting info to make the point that you should post the year/series. great post. since have upgraded to 99s.
Old Apr 20, 2008 | 06:44 PM
dhahlen's Avatar
I am going to test it out on some old lights, i have a set of 99's with a few scratches
Old Apr 20, 2008 | 07:09 PM
dhahlen's Avatar
tested it on my old *** avc-r... worked pretty decent for a half assed job...
Old Apr 20, 2008 | 07:44 PM
Smitter's Avatar
94 Single Turbo FD
it'll work fine. use a 1500 grit, and give em a shot of clear coat when u are finished
Old Apr 20, 2008 | 07:45 PM
dhahlen's Avatar
Man, you really have to put some elbow grease into that polishing compound. I didn't press hard enough the first time and it looked like *** so I re-did the polish and used quite a bit of force... and these are my results.
Notice the first pic, the deep scratch by the amber light..... and then look at the final two pics... that scratch was deep enough for me to catch my nail on and this took it all out, I am very, very pleased with the outcome....
Old Apr 20, 2008 | 08:14 PM
rlee429's Avatar
Chocobutt
will wet sanding get rid of the purple haze on the tail lights?
Old Apr 20, 2008 | 08:17 PM
dhahlen's Avatar
someone just asked me that...
if it's in the plastic, the polishing compound will get rid of it... if it's stained under the plastic, then no.
Old Apr 20, 2008 | 08:35 PM
FDNena's Avatar
I
You don't need to wet sand them. There is a kit sold at Auto Zone for about $10 for plastic polishing.
It comes with a drill attachment and the pads have the compound right on them. Mist the tailight with a bit of water and just buff with your drill. I have done it to a few tails and headlights too. They look great afterwards. I find it easier to take them off the car and just sit and do them in your lap. If I remember the name of the kit I will post it later.
Old Apr 20, 2008 | 09:38 PM
purerx7's Avatar
Registered User
their was a really good write-up on the supraforums, they did 2000 2500 then 3000, the problem is finding 2500 3000 paper
Old Apr 21, 2008 | 12:06 AM
njstreetrx7's Avatar
u shouldnt sand the tails because they are smoked from factory and if u sand enough the tails will start to look more purplish or fades black. i usually just rub and buff lightly w compound
Old Apr 21, 2008 | 12:08 AM
dhahlen's Avatar
I can always re-smoke them, but thanks. I'll deal with the fading if it happens... that scratch was nasty looking.
Old Apr 21, 2008 | 01:36 AM
omegapartyanimal's Avatar
www.easypckits.com has lots of high grit sand paper getting into the micron range. Price isn't too terrible too. Also, you might be able to email the guy requesting specific grits.
Old Apr 21, 2008 | 03:45 PM
DavidHolmesIII's Avatar
Marvelous Hedonist
Here is my method of restoring the tails, its for an S4, but you could use the same method for the S5 and FD's. It would be easier actually.
https://www.rx7club.com/2nd-generation-non-technical-pictures-198/s4-tail-light-restoration-746933/
I found the fine grit paper in the model section of a local hobby store.
Old Apr 21, 2008 | 03:58 PM
sevensix's Avatar
rotor rotor pow.
yeah 2000 grit isn't so great. i tried this on my front indicators before then following with plastic polish. its definitely not 100%. not worth it imo. better to have a scratch or 2 than having a haze.. i would just use polishing compound , nothing as harse as sandpaper. 3000 grit sounds promising though
Old Apr 21, 2008 | 04:32 PM
dhahlen's Avatar
Do you guys haev an example of this 'hazed' look - cause these things look clear as glass to me...
Old Apr 21, 2008 | 05:15 PM
seven lust's Avatar
No need to clear coat them.
the lights fade and turn purple due to the sun heating up the plastic, kind of like some window tint fades to purple or the paint on a car. Any how I do this quite a bit , when converting the tails and center piece. ( pm me if interested in more info) I remove all the scratches and fade for my customers. I do sand them down and then polish them back up. I also sand out the smoked plastic to remove any scratches or scuffs. If you spend some time on it, know the technique of it, you can get them looking quite good. I have used the drill bit stuff, but I find it to come out much better the good old fashion way of doing it all by hand. It will kill your arms, but when you are done it will look great. good luck, John
Old Apr 21, 2008 | 05:23 PM
Sojin's Avatar
Well i have a 2gen but with the flash to pass i wet sanded it then buff it and it looked better then new if u know how to work it then go all for it but if now take it slow thats all i have to say
Old Apr 21, 2008 | 05:58 PM
dhahlen's Avatar
This was my first attempt ever at wet sanding anything, the lights turned out really good. I actually have the other light left to do... I'll try and take some better before/after pics to give you guys better results along with a walkthrough or more pics... but it's actually pretty easy if you read my first post.
Old Apr 28, 2008 | 06:57 PM
cesarx7's Avatar
The Dirty Mexican
http://www.autopia.org/forum/click-b...storation.html
Old Apr 28, 2008 | 07:41 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
Next time, soak your sand paper in water overnight or at least a few hours before you begin to wet sand with them.
Old May 2, 2008 | 06:26 AM
KBSRX7's Avatar
You can wet sand and polish ANYTHING. Paint, metal , glass, plastic, even my *****.
fastsaab
Aug 19, 2015 11:42 AM
