Stuck With 2 Bolts On Rear Passanger Tire
Old Apr 19, 2008 | 08:21 PM
NorCalFCdrifter's Avatar
NorCalFCdrifter
Question Stuck With 2 Bolts On Rear Passanger Tire
Trying to replace the subframe cause i believe it's bent due to a previous accident?
Can U help me ?
Trying to get THAT BOLT out but it about 1/2 way in still car frame is in the way, and trying to disconnect the Axel from what is left from the Brakes ?
Attached Thumbnails Stuck With 2 Bolts On Rear Passanger Tire-p1000773.jpg   Stuck With 2 Bolts On Rear Passanger Tire-p1000776.jpg
Old Apr 20, 2008 | 01:17 AM
slpin's Avatar
7th Heaven
the easiest way to remove the half shaft is get an impact gun and bang the circled nut loose
take the 4 bolts out from the back, remove from flange and just hit it once or twice to get it out.
Old Apr 20, 2008 | 04:13 AM
NorCalFCdrifter
thx still the control arm is Wedged in there due to the one bolt stuck in cause the frame of the car =o(, And body know an Easy way to Remove this ?
josef 91 vert
23
Sep 3, 2015 11:20 AM
