Haltech engine issues
Old Apr 19, 2008 | 03:53 AM
wackaloo13's Avatar
engine issues
S5 TII hbp.
I had a haltech e6x installed and everything was working. i switched to a haltech e8 and im having some issues. Before the car never smoked as much as it does out of the tailpipe. It is bellowing grayish smoke. The car will start but the engine shakes quite a bit, it wont rev and it dies if i have less than 30% throttle. I have not noticed it burning oil but i have not been able to have the car idle or drive so it has not had much time to burn oil. I compression tested the motor and it has great compression. I am getting spark from the coils. Both rotors are getting fuel.
What should i check next?
Is there a way to test a coil to make sure it is putting off a strong enough spark? (stock s5 coil)
Old Apr 20, 2008 | 08:43 AM
RETed's Avatar
Is the E8 tuned?
-Ted
Old Apr 20, 2008 | 03:18 PM
wackaloo13's Avatar
i loaded one of claudio's e8 map for s5 with 550/1600 injectors and stock ignition.
The Shaolin
Sep 14, 2015 07:50 PM
rx7jocke
Aug 15, 2015 03:36 PM
befarrer
Aug 14, 2015 04:18 PM
