Apex seals or ecu?
Old Apr 19, 2008 | 01:02 AM
Asymptote's Avatar
Newbie
Thumbs down Apex seals or ecu?
Hey guys,
Im looking at picking up another rx7. I got my last one for 500 buck with a blown engine, but i am parting it out and using the engine for my kit car.
Anyways, since i have all these extra parts laying around from that car, i was looking at picking up an rx7 with a good engine for cheap and fixing it up with the parts from my current car. I found a car online that looks like a good canidate. however i dont know enough about the rotaries to know if the problem listed is cause by low compresion due to blown apex seals, or like the seller was trying to say, a vacuum line or ecu problem. Anyways here is the quote from the add.
"fixed oil leak
runs smooth, but rev's
up really slow,(it has no power, it drives tho just really slow) has something to do with vaccum lines or computer???,
its hard to start(it gets flooded out)
driverside window rolls up and down when it wants, "
I have checked the FAQ and didnt see anything so i though some one could help me out.
I was just wondering if it was worth my time to look into it. Thank you guys.
Old Apr 19, 2008 | 01:21 AM
shadoe's Avatar
#1 RX7 Homo
sounds like the product of a nonactive rotar i'd be very cautious about that one one side might be blown
Old Apr 19, 2008 | 10:24 AM
polito Racing's Avatar
so you got pistons oh wow
yeah that sounds like is either low on compression or one of the rotors is totally gone.
Old Apr 19, 2008 | 02:40 PM
eriksseven's Avatar
Make Money.
That part about "running smooth" sounds contradictory to the rest of the description.
I'd stay away from it unless you can verify compression results...
Old Apr 19, 2008 | 08:37 PM
Sideways7's Avatar
Yep, test for compression. Its real easy. Pull the EGI fuse, then pull a plug on the front rotor, then crank. Replace the plug then repeat on the rear rotor. Listen for 3 solid, even pulses on each rotor. Anything otherwise means a bad motor.
If it has good compression it could be screwed up timing, a bad injector, or other fixable issues.
Old Apr 20, 2008 | 04:19 PM
Asymptote's Avatar
Newbie
Alright, thanks guys. I Think ill just wait for a different, better deal to come my way. Im not in a hurry.
Thank you
Old Apr 20, 2008 | 04:26 PM
Sideways7's Avatar
Thats a good idea, that car sounded very questionable.
Old Apr 20, 2008 | 04:40 PM
RyosukeD's Avatar
Yo dawg, Im happy for you
Where in Oregon are you and the car? Just curious.
Old Apr 21, 2008 | 12:54 AM
areexdrift's Avatar
Drift Heaven
its very quetionable..
just last month i found a guy in washington selling a 7. he did an engine swap and said he knows nothing about rotory engines
Old Apr 21, 2008 | 10:49 AM
Asymptote's Avatar
Newbie
I'm every where.... or so it feels like, lol. Seriously though im in Klamath Falls for college, but live near Salem, and my dad works out of Vancover. So I pretty much have this state covered.
And i think i saw that 7, where they swapped the engine, and then tried to mess with it, and now it wont run correctly?
Old Apr 21, 2008 | 12:04 PM
areexdrift's Avatar
Drift Heaven
Maybe, it was a 1st gen, and it wouldn't start. i dont think it even had the right plugs in it.
Old Apr 21, 2008 | 12:10 PM
AreExSevenProject's Avatar
drift city
I talked to this guy and he said the engine no longer starts at all. The apex seals were toast...
Im pretty sure at least it was the same posting on craigslist...
So i wouldnt worry about gettting that car...
Old May 2, 2008 | 12:35 PM
driftmunkey's Avatar
I Am Demon
Klamath falls? No ****, goin to OIT? If you need help on the rotary pm me, nobody in this town knows anything about them, DONT take it to a shop here or you will not see it for a long time.
Clubuser
11
Aug 31, 2015 12:25 PM
