88 n/a fuel problem
Old Apr 18, 2008 | 07:17 PM
l-bone's Avatar
Question 88 n/a fuel problem
So check it, I just rebuilt my motor and I dropped it in yesterday. I hooked everything up, put some oil and coolant in it, cranked it and got nothin'. Its getting spark and its getting plenty of fuel into the fuel rail, but the injectors aren't spraying it (or spraying enough). I'm pretty sure the fuel injectors work cuz they did a little over a month ago. I checked all the ecu inputs and the fuel pump for reference voltage and everything checks out fine. Any help would be deeply appreciated. I'm out of ideas!
Old Apr 18, 2008 | 07:25 PM
$500CaR KinG's Avatar
NM
keep tryin and tryin and tryin and when u think you have tried enough try some more if its a fresh rebuild youll need to build up some compression if you want it to start
Old Apr 19, 2008 | 01:16 AM
misterstyx69's Avatar
Retired Moderator, RIP
Change the Fuel lines at the engine.The Rubber ones.the One from the Fuel filter goes the the Primary Rail(recheck that area)..teh retrurn Comes from the Secondaries and then back to the Tank...If that is Messed up and you have it in Reverse the Fuel will be in The rail but NOT go the the Primaries..therefore NO Start.Also make sure your AFM is plugged in,the CAS is Stabbed Correctly and the timing Marks are In "sync" with each other.
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
