loud continous beep with exterior lights flasing?
Old Apr 18, 2008 | 05:43 PM
Airceo13's Avatar
hey guys so i just got a free 88 rx7 with a blown motor... anyways, so i charged up the battery and tried starting the motor so to confirm the motor is really blown... anyways a few seconds after i turned the car on, this loud continous beep started going and all the exterior started flashing... what could it be? is it the stock alarm system?
Old Apr 18, 2008 | 05:45 PM
rotary_phoenix's Avatar
I miss Austin
Police raiding the crack house next to you?
Old Apr 18, 2008 | 06:15 PM
Airceo13's Avatar
sweet.... no for reals tho, my tailights and signal lights will flash all at the same time... is it the stock alarm system?
Old Apr 18, 2008 | 06:20 PM
shadoe's Avatar
#1 RX7 Homo
its not a stock one it could be aftermarket tho thats what it sounds like
Old Apr 18, 2008 | 06:22 PM
SimplyComplex's Avatar
pfft.
I'm quite sure it's the stock alarm that's making your lights flash. But the horn should be honking as well. Try to actually honk your horn. If it works, then i'm not sure that it's the stock alarm.
As far as the beeping goes, it's probably the coolant or oil level sensor that's beeping at you because, well, your motor is blown.
Old Apr 18, 2008 | 06:23 PM
Airceo13's Avatar
the beep is inside the car... and i can also honk the horn... so its mostlikely the stock alarm system then? how do i rest it or remove it? is there a write up somewhere?
Old Apr 18, 2008 | 06:27 PM
shadoe's Avatar
#1 RX7 Homo
but yes its an alarm system the beeping is your oil or coolant just as simplycomplex said if its stock there are methods in the faq's to shut it off
Old Apr 18, 2008 | 06:28 PM
Airceo13's Avatar
alright thanks im gonna go look through it now
rx7shirley
Sep 2, 2015 02:11 PM
