idle problems
Old Apr 18, 2008 | 01:57 PM
Templeton's Avatar
is tempted
idle problems
ive recently removed egr bac aws, vacuum rack and modified my throttle body, the lowest idle i can turn out of the car is about 1300 through adjustment of the idle screw and double throttle plates. does that sound right? any tips on lowering it would be greatly appreciated
Old Apr 18, 2008 | 02:01 PM
well uhhh's Avatar
I wanna go fast
what year car, turbo or n/a. did you leave thermowax on? vac leak? i assume you are talking about the idle stop screw? i would suggest checking TPS after you check for vac leaks. Did you make sure to take out the fast idle cam?
Old Apr 18, 2008 | 03:19 PM
Templeton's Avatar
is tempted
88 n/a. thermo wax removed, fast idle cam removed, and ive already check the car over a few times for vacuum leaks the adjustment screw on top of the throttle body if its called the idle stop screw then yes.
Old Apr 18, 2008 | 08:44 PM
Templeton's Avatar
is tempted
noone can help me out here?
Old Apr 18, 2008 | 11:07 PM
blackedoutFC3S's Avatar
HKS obsessed
mine had idle problems because the idling screw that was supposed to keep a steady idle that was above the TPS sensor was broken off im guessing yours is not though... your TPS could be at fault though
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
