Changing suspension bushings
Old Apr 17, 2008 | 11:46 AM
Spectator's Avatar
On all 4 wheels.
-How long does it take if I have the proper tools?
-What tools/pullers will I need?
I have been told a couple of times its the shittiest job to do...Is it that bad?
Thanks.
Spec.
Old Apr 17, 2008 | 12:15 PM
YaNi's Avatar
RIP Mark
It's not hard, just takes some engineering, and ALOT of time. While you have the rear trailing arms off you should replace the DTSS bushings.
I used a ball joint press, a bench vise, and an assortment of sockets to remove all the bushings except the front control arm D bushings. For those I used a cut off wheel to remove the metal sleeve.
Just make sure you don't snap the caliper bolts! I broke a bolt on each rear caliper, which ended up making the job 3x harder.
Old Apr 17, 2008 | 10:20 PM
Spectator's Avatar
No worries, my caliper bolts are free, I just removed them and my car never seen a winter in 10 years.
How much time did it take you?
Spec.
Old Apr 17, 2008 | 10:28 PM
YaNi's Avatar
RIP Mark
I have no idea on time estimation. The car is nearing the end of restoration, so when I took something apart it got cleaned and painted. If I didn't have any snapped bolts I could probably do it in <8 hours.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
