Fc bad idle, backfire
Old Apr 17, 2008 | 02:34 AM
Spirit Rx-7's Avatar
rotard
well just started the car this morning, and the engine turns over and holds idle, but it sounded bad, like a lawnmower, and idle was very low. it was also backfireing like crazy. what could be the problem? i also just topped off the oil before i started it, it looked fine, but after i started it, oil went a lil low. sounded as if its runnin with one rotor.
the other day it was running fine, just that this morning, the problem began as i started it. car is a 1991 n/a. so, what should i start looking into?
Old Apr 17, 2008 | 04:09 AM
RO7ARY's Avatar
Hey mate check the sparkplugs they could be fouled.. if they seem fine and relativley clean get a compression test done.
cheers
Liam.
Old Apr 17, 2008 | 03:33 PM
rotard
ok, so i took out the plugs just now, and the rear housing plugs seem dry, but the front ones are a little wet, seems like oil.
here are pics of the front trailing and leading plugs.
so just get new plugs? dont think i blew a oil seal as i have no smoke what so ever.
Old Apr 17, 2008 | 06:27 PM
rotard
well, got new plugs and it ran a little better, but on start up, it still idles pretty bad. it sputters, and its really low. what can i check on that?
Old Apr 18, 2008 | 07:27 AM
solareon's Avatar
run a compression test. my fc did the same kind of thing and it turns out one rotor was completely blown =(
Old Apr 18, 2008 | 08:13 AM
rotard
checked compression recently, it was good. so i guess it was just fouled plugs, thanks for the help guys.
Old Apr 18, 2008 | 08:16 AM
bikeboy23332's Avatar
dude i bought my car running like that. i didn't know about them then it was smoking, idleing rough, and was blown. . running on one rotor. help me!!!
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
firzen
Sep 15, 2015 12:04 PM
Frisky Arab
Sep 4, 2015 06:17 PM
