got a question for ya
Old Apr 26, 2002 | 04:24 PM
1bad7's Avatar
in front of the UIM there is a big black box which i assume is a vacum chamber (has 2 hoses going to it on the right side). i tried blowing in the nipples and it seems that air travels freely both ways. can someone tell me what this chamber is for and if its alright if i remove it ?(just connect the two vacum hoses directly to each other). thanks
Old Apr 26, 2002 | 04:43 PM
Bucrx7's Avatar
The black box is just an empty box that stores pressure/vacuum and is used when needed. If you remove that box then your turbo system will not function properly.
Old Apr 26, 2002 | 04:56 PM
maxpesce's Avatar
Ex fd *****
It is a PRESSURE chamber that stores the pressure required (8psi) to actuate the Turbo Control Valve (TCV), and Charge Relief Valve (CRV)
Old Apr 26, 2002 | 05:12 PM
1bad7's Avatar
ok cool, guess im just gonna leave it then. thanks guys
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
