Microtech problem with lt8 need help
Old Apr 9, 2008 | 04:05 AM
jotary20b's Avatar
is 13brew with a lt8 -when the hand controller is in,the car starts to boost then the controller flashes battery-and there is a red light on the unit that flashes then goes away after the car is cruiseing-please any help
Old Apr 9, 2008 | 04:19 AM
rx72c's Avatar
Top Answer: 1
Check your voltage isnt going above 16V or going below 8v.
do a datalog. youll see it.
Old Apr 9, 2008 | 04:22 AM
jotary20b's Avatar
HI
it was going about 15 16v -what can be causing this? and what can be done to fix
Old Apr 9, 2008 | 06:48 PM
rx72c's Avatar
Top Answer: 1
Your alternator regulator is stuffed or your wiring is incorrect.
Get the alternator tested at auto elec and if its ok wiring is bad.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
