Alternator wiring qustion
Old Mar 31, 2008 | 06:40 PM
Joemybucket's Avatar
I am putting a 83 12A into a VW Beetle, on the back of the alternato there is the plug with 2 wires, shaped like the letter "T", which one is for the Alt. warning light? and is the other a hot wire?
Thanks
Old Mar 31, 2008 | 10:07 PM
Siraniko's Avatar
RX for fun
you need an ignition wire to the top terminal (T connector) for alternator to start charging. the bottom you dont need but you can connect a Volt meter
Old Apr 1, 2008 | 03:45 PM
Thanks
Old Apr 1, 2008 | 05:17 PM
BASTARD's Avatar
FYI... easy way to tell if you have it backwards is to put a test light between the neg battery post and neg battery cable when the car is off... if it lights up you have it wrong and the drain will slowly kill your battery
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
