Microtech x4 wiring question
Old Mar 31, 2008 | 03:45 PM
cpnneeda's Avatar
RAWR!!!!!!!!
Question x4 wiring question
Will I use the stock ignitor with the x4 box? I am about to wire this and an lt10 in a FD, and was curious as to whether or not it is used? If not, I'll probably pull it out of the car. Anyone know?
Old Apr 1, 2008 | 04:13 PM
rx72c's Avatar
Top Answer: 1
If your using x4box you have to use bosch coil packs.
ANd if your computer is programmed to use the X4box you have to use it.
Other wise if you want to run stock ignitor and coil packs it has to go back to microtech.
Old Apr 10, 2008 | 08:19 PM
RX7 13B 4 UR AZZ's Avatar
you dont have to use bosch coils you can use 4X FC trailing coils without the igniter and they work great.
The Shaolin
Sep 14, 2015 07:50 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
