Sponsored by: CARiD
Proper method to retoque tension bolts?
Old Mar 31, 2008 | 02:09 PM
apexFD's Avatar
Hey guys,
So i know that it is common practice to re torque the tension bolts usually on every clutch job... But what is the proper way to do this?
I am aware of the FSM torquing pattern, but do you have to remove the bolt completely to retorque it properly? IE. Remove bolt#1 and then retorque, remove bolt#2 then retorque??
Thanks in advance.
=Ben
Old Mar 31, 2008 | 04:25 PM
B6T's Avatar
B6T
ERTW
I would loosen it off and pull it out to put some oil on the threads and maybe clean off the shank of the bolt.
Old Mar 31, 2008 | 05:05 PM
apexFD's Avatar
I have contacted Rob Golden from pineapple racing about this. Here is what he had o say.
"I have not found a need for it in almost all applications. Long high rpm vibration can loosen bolts. Try marking a bolt so it's clocking to the plate can be seen clearly. Loosen and retorque the bolt. If it moves past the mark, it could mean you should retorque. That assumes you are using the same torque spec. as the builder. Also remember to lube the threads w/ oil. You will probably loose a little coolant doing this. rob"
So ill give this a try and see how it works.
=Ben
cewrx7r1
15
Aug 6, 2018 11:41 AM
toplessFC3Sman
Mar 20, 2018 01:54 PM
dradon03
Sep 18, 2015 05:57 AM
MikeTee55
Sep 8, 2015 08:05 PM
Enzo1944
Sep 6, 2015 08:57 AM
