1/4 times ???
Old Apr 24, 2002 | 05:44 PM
Revin7's Avatar
Smile 1/4 times ???
Well i'm gonna be running my car at the the track for the first time this weekend. I was wondering what were peoples times when there cars were stock or near stock. My only mods are an apex-i intake, apex-i gt exhaust. By the way my car is running fine, no problems with boost. Any tips would be appreciated .
Old Apr 24, 2002 | 05:58 PM
rynberg's Avatar
At sea level, depending on your skill and the track surface, you could run anything from mid 13s at about 104-106 mph to low 14s at 100 mph.
If you are significantly above sea level, your times will be slower, even with a turbocharged engine.
Old Apr 24, 2002 | 07:01 PM
turbojeff's Avatar
Do it right, do it once
Bone stock my 93 R1 ran 13.954@ 99.45 mph.
With a DP, CB and Efini y-pipe it ran a 13.598 @ 102.85 mph.
Original motor and turbos.
Jeff
Old Apr 24, 2002 | 07:11 PM
justin's Avatar
My first run ever 15.2 horrible wheel hop and missed third gear.
My best now is 12.3 @116 w/every bolt on possible and launch kit,stock eng/turbos/inj@13.5lbs.
The first thing I wish I had when I started drag racing was a launch kit,get one as wheel hop and
a 2.6 60'time is no fun.The next thing you need is a short shifter....
Old Apr 24, 2002 | 09:24 PM
ErnieT's Avatar
Living life 9 seconds at a time
Re: 1/4 times ???
With the same mods as you I went 13.2 @ 105mph on street tires.
Old Apr 24, 2002 | 09:31 PM
Ehughes's Avatar
PFS intercooler and catback, Power FC, shortshift, ACT clutch, stock turbos, inj, fuel pump and street tires.....12.75 @109mph.
Old Apr 25, 2002 | 12:28 AM
GsrSol's Avatar
Z06 powered FD
I'm gonna guess that your best time will be a 13.6-7, it's probably capable of a little more.
Old Apr 25, 2002 | 02:54 AM
voodooracing's Avatar
when i still have the stock twin turbo setup (97), i ran no filter, straight pipe turbo back, HKS F-con, i ran best 12.89@108mph. shifting before redline helps...
Tylerx7fb
39
May 27, 2019 12:45 PM
incubuseva
14
Sep 3, 2015 12:37 PM
LMBTG
Aug 15, 2015 01:43 PM
