Haltech e-8 tuning questions.
Old Mar 22, 2008 | 03:49 PM
no-boost93's Avatar
Question e-8 tuning questions.
one is there a tuner in the chatt tn or surounding area that can effiently tune a car with high boost. can i set three different tunes or boost settings into the e-8 without a piggy back. and if i need a piggy back will the avcr do the job that is the way it was intended to be set up.
next question the car has some custom wiring that makes it hard to trace. i am getting fuel pressure on the guage and at the rail. (guage also) strong battery (yellow top with charger hooked up) but no spark. tried it on the dual msds (ehich i do not know anything about) and i tried it with the plug that skippes the msds so it should have worked on the stock coils. i got nothing both ways. do not know were to starte. will the e-8 come with base map that will allow the car to at least crank so i can check for oil leaks and ect, or will all of this have to be done at the dino?
please pm if you think you may have any info that would help.
thanks, joe
Old Mar 22, 2008 | 05:41 PM
jacobcartmill's Avatar
just dont care.
FB? FC? FD?
what kind of ignition setup?
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sccarally
South RX-7 Forum
Oct 8, 2015 05:27 PM
Xepez
2nd Generation Non-Technical and pictures
Sep 22, 2015 03:15 AM
