Rx7 S4 Bad idle
Old Mar 22, 2008 | 07:31 AM
zvury's Avatar
Rx7 S4 Bad idle
Hey guys
im new here and also new with the rotarys as well but always up for a challange.
My mate just bought Rx7 S4 got a bad idle and smoked like CRAZY what was the stuffed turbo so we fitted a new turbo and got the car running and now we got this problem.
is idels at 1200rpm, rock side to side like crazy(we just replaced both engine mounts and noticed it) is smokes slightly but when i pick the revs up to about 2000rpm it smooth as and when you go for a spin around the block it drive very well except for when we stopped and car went back to idle. ( it has **** LOAD OF POWER HEHEEHEHE brakes traction at 80km with ease)
had a quick look around for intake leaks and found the air bypass control leaking a bit so we resealed that.
Car has new NGK rotary plugs(from rotary shop), new leads, new vacuum lines, fuel filter, oil filter, oil
Here's a clip i have posted on you tube for people to look at. Also the engine is warmed up not cold(you think the engine ganna bounce out at cold)
Thx
Jason
http://www.youtube.com/watch?v=28SY9H3eRbw
Old Mar 22, 2008 | 04:43 PM
zvury's Avatar
Anyone????
It also running a microtech MT-8
unknown of what mods have been done think they might be stock injectors and pump as well.
Old Mar 22, 2008 | 11:36 PM
osgoodc's Avatar
post in the other FC section this is just a pic section
Old Mar 23, 2008 | 12:16 AM
polito Racing's Avatar
so you got pistons oh wow
you are in the wrong section but look for a vaccum leak. good luck
Kyo
Apr 13, 2019 09:24 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
