Sponsored by: CARiD
unhealthy idle + Horrible breaking up and sputtering past 3000 rpm please help!
Old Mar 13, 2008 | 10:05 AM
ferrariyellowfd's Avatar
angry weed eater
Exclamation unhealthy idle + Horrible breaking up and sputtering past 3000 rpm please help!
My car has a unhealthy sounding low idle after it starts to heat up, and it sputters and breaks up after 3000 in every gear, My boost gage shows it making boost yet the car will not pull and it sounds as if it is ignition or starving for fuel, I was told it could be the LIM gasket, but no luck in being able to find anything wrong with it. Plus the intake manafold stays alot colder then it did in the past.. any clue guys???
Old Mar 13, 2008 | 10:15 AM
angry weed eater
If somone in the GA area that has built and been around these cars for a wile, and would not mined meeting me somewhere I'll buy you lunch or dinner and let you drive the car and see if you can figure it out, I'm at a loss
Old Mar 13, 2008 | 09:52 PM
RotaryBred's Avatar
Lost You in the Rear View
breaking up and sputtering sounds more like too much fuel to me...
Old Mar 14, 2008 | 08:51 AM
angry weed eater
Originally Posted by phoenix7
have you searched for anything yet? Off the top of my head? TPS is causing the stumbling in all gears. How's your timing? When was the last time you checked to make sure everything was within specs?
Yeah I have checked on the small things, I'm afriad it's more sirius then that, Here is a picture of my motor bay, and out of the top intake pipe, it sounds like a hamster wheel and a slite ticking
Queppa
Nov 18, 2024 03:47 AM
Kyo
Apr 13, 2019 09:24 AM
Microtech
30
Apr 23, 2016 06:37 PM
PhillyFC
Aug 21, 2015 06:36 PM
ncds_fc
Aug 15, 2015 10:06 AM
