Power FC Stock or near stock values in sensor check?
Old Mar 9, 2008 | 04:46 AM
DarkLikePoe's Avatar
It's dark like Poe.
Question Stock or near stock values in sensor check?
If anyone running a PFC in their sequential turbo FD can tell me the function pattern they are seeing on the CCN (charge control)? I'm trying to figure out why I'm not getting more than 3-4psi under 4000 RPM, and I think my charge control valve is malfunctioning, given that I see a constant ON indicator, regardless of load or RPM.
Thanks in advance.
EDIT: After some searching, I discovered what I think I need to see here: http://www.autosportracetech.com/RX-...erOverview.htm. However, I'd still like to know how the values of the CCN and TCN sensors change on the PFC throughout the rev range, so if anyone has that information, I'd be much obliged.
Old Mar 9, 2008 | 05:15 PM
arghx's Avatar
rotorhead
there is some vague stuff in the FSM in the ECU pinout section. but that assumes the PFC operates that stuff in a similar fashion.
Old Mar 10, 2008 | 12:05 AM
It's dark like Poe.
What I'm asking is for someone to run his FD while watching the Sensor/Switch Check function to see when the CCN and TCN actuate. My CCN is on constantly, and the TCN never clicks on at all. Given that the twin turbo control is largely vacuum-controlled, the PFC is essentially monitoring an issue it can't control. Knowing what the PFC should be seeing in a functioning setup will help me diagnose the problem.
Old Aug 3, 2012 | 01:56 PM
danny hahn's Avatar
thought to answer this as I did some searching and verified with my commander:
with base mapping the TCN indicator should turn on at around 5000 rpms and boost.
I came across this when looking for normal pfc operations as shown on the commander.
CaptainKRM
14
Aug 26, 2015 09:52 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Clacor
Aug 14, 2015 09:17 AM
