Yeaaaaaaaaa powdercoat :D
Old Mar 7, 2008 | 01:53 PM
hurleysurf24's Avatar
wtf rotary wtf
Well since im rebuilding the car I decided to powder coat some things ... heres a few pieces ... lots more are being done.
Here's a sneak peak
Old Mar 7, 2008 | 01:54 PM
RRTEC's Avatar
Rotartist
Nice.. do it yourself?
Old Mar 7, 2008 | 01:56 PM
wtf rotary wtf
if i had the time to yea i would have .. but i sent it out
Old Mar 7, 2008 | 02:25 PM
Hypertek's Avatar
Slowpoke
nice
i wish i could have the downtime to rip my car apart but i drive it every day.
Old Mar 7, 2008 | 02:26 PM
RotaryResurrection's Avatar
Oh, I see how it is. Come to me when you need information, but send your powdercoat work out to someone else. Alright, I'll remember that.
Old Mar 7, 2008 | 02:28 PM
RRTEC's Avatar
Rotartist
^ No joke.. Kevin's Chrome looks freakin SWEET!!
Old Mar 7, 2008 | 02:45 PM
wtf rotary wtf
yea kevins is sick.
kevin yo know you are #1 in line for my business, but I couldn't wait til ya came down here to pick my car up
If I'm able to make it up to NC the first week of April for the Dragon I'll swing by on my way back down
Old Mar 7, 2008 | 07:59 PM
People ship engines and manifolds every day of the week.
Old Mar 8, 2008 | 02:27 AM
wtf rotary wtf
yea i dont have the tools or expertise to pull the engine out by myself though :/
i <3 you kevin !
Old Mar 8, 2008 | 02:40 AM
wtf rotary wtf
more powdercoat
Old Mar 8, 2008 | 02:44 AM
Bama420's Avatar
Upside-umop Racing
But why is there an Acura emblem on your keys?
Old Mar 8, 2008 | 02:57 AM
wtf rotary wtf
my daily is an acura tl type s
Old Mar 8, 2008 | 03:33 AM
GohtretFC's Avatar
What did you use?
I saw a craftsman powdercoating machine and the powder at sears the other day. I was tempted to get it and see if it worked good. It was only $200 or so.
Do you think you could powder coat parts of your engine with it still in the engine bay and just cover other stuff up?
Old Mar 8, 2008 | 11:09 AM
PC is not like spraypaint. You have to have each part off, down to the bare metal. Like in the case of an alternator, there can be no electrical, plastic or rubber internals or externals left in place. You have to pretty much disassemble each part down to it's simplest form.
You have to prep the parts, usually by beadblasting and then rinsing, blowing dry with air, and wiping off with a chemical agent.
Then, any mating surfaces, threaded holes, etc. get masked, plugged, and capped off to keep the coating out. As you know if you've watched hotrod buildup shows on TV like american chopper, if powdercoat gets in the wrong places, it is a BITCH to get out, and nothing fits right again. Powdercoat is thicker and stronger than paint.
Then the part gets preheated for several minutes near 400*. Then removed and the coating sprayed. Then the part gets baked for about 15-20 minutes near 400*. This is what makes the coating turn from powder to gel, liquify and flow evenly across the surface leaving a glossy finish. This is also what makes it hard and tough.
Old Mar 8, 2008 | 11:53 AM
wtf rotary wtf
yea they forgot to mask off some holes unfortunately grrrr .. nothing a drill cant take of though
Old Mar 8, 2008 | 11:55 AM
RRTEC's Avatar
Rotartist
mmmm powdercoat..
Old Mar 8, 2008 | 01:18 PM
rx7fan1903's Avatar
Drifter Fo' Life
lookin' good!
Old Mar 8, 2008 | 01:24 PM
That's one thing I can say...I am pretty meticulous about masking/capping/plugging things that do not need coated. Part of it probably comes from the fact that I work with these same parts and know what can and cannot be coated. But as a rule, any holes and mating surfaces should be protected, even if you dont know what they are used for.
Old Mar 8, 2008 | 06:47 PM
willub and company's Avatar
Pobody's Nerfect
now on a technical note, wouldn't it be a bad idea to coat the contact surfaces on the pulleys? looks good none the less.
Old Mar 8, 2008 | 11:42 PM
No, not a bad idea at all. Won't affect anything. But it will wear off over time, depending on how tight the belts are.
Areas like that would be very difficult to try and mask anyway, and you don't really know exactly where the belt would ride/how far to mask. I'd rather let the belt cut it's own path after installation, than to have a gap in the coating where it can be seen.
Old Mar 9, 2008 | 01:50 AM
wtf rotary wtf
exactly .. that was one of my concerns originally, but then i thought about it logically and realized it will wear pretty quickly with the amount of revolutions generated from the pulleys on the belt
Old Mar 9, 2008 | 11:57 AM
Pobody's Nerfect
ok, just making sure. i figured it could either
a) screw the belt up
b) slip like crazy
now i know! looks like you took the color right out of Aaron Cake's book.
Old Mar 9, 2008 | 02:35 PM
Looking at the pics again, did they coat over all the threaded studs on the LIM, and all the gasket mating surfaces? IF they did, they are a bunch of rookies. I am not a pro coater, but I know better than that. Once those studs are coated, it's more likely they would snap in half before you could get a nut to thread onto them because of the thickness of coating. And the coating is not perfectly flat once applied, so it's a no-no to coat flat machined mating surfaces because they won't seal as well afterwards.
Old Mar 9, 2008 | 03:56 PM
wtf rotary wtf
no they did not coat the gasket surfaces .. they arent that stupid
they only hit one or two of the threads
Old Mar 10, 2008 | 04:02 PM
jm93rx7's Avatar
Committee Member #3
Who is doing the motor?
