will these rims fit my car?
Old Apr 22, 2002 | 06:06 PM
CYAL8R66's Avatar
my buddy has a set of Enkei Sportline wheels, they are 17X7 and 4 lug. I have an 86 N/A with the 4 lug (phone dial) rims. does anyone know if these will fit?
Old Apr 22, 2002 | 06:10 PM
nitroracer's Avatar
Dub'N
whats the wheel demetion
Old Apr 22, 2002 | 06:18 PM
RETed's Avatar
Need offset or backspacing...
-Ted
Old Apr 23, 2002 | 05:38 PM
CYAL8R66's Avatar
i found some on E-bay actually...would they fit my 86 N/A?
- 17'' ENKEI SPORTLINE 4 LUG RIMS.
- YOKOHAMA AVD H4'S 205/40R17/80H.
- TREAD IS 50/50
this is all the info i could get...
any help would be greatly appriciated, thanks!!!!!
Old Apr 23, 2002 | 05:47 PM
Flobb's Avatar
Rattle can retard
You need the specifics of the bolt pattern and offset and width.
i.e. 4X110, 4X110, 4X114.3, etc...
+50, +40, +35, etc...
6in., 6.5in, 7in, etc...
Old Apr 23, 2002 | 06:04 PM
Ryde _Or_Die's Avatar
I believe the 4 lug FCs are 4x114.3, so check that out. And if they are the right bolt pattern I guess they would fit, but not always right. Not sure what offset you want, think like 45mm.
Old Apr 24, 2002 | 08:19 AM
CYAL8R66's Avatar
alright i found soime 4x114.3....the offset says +42...are these ohkay? also whats the biggest size i could fit on an 86 N/A....17 prolly eh?
why do some of them specify that they are only for FWD cars?
thanks for the help guys
Old Apr 24, 2002 | 04:52 PM
Flobb's Avatar
Rattle can retard
FWD only generally denotes that the offsets are really high. 17's if probably the biggest you would want to go. You can do 18's but there isn't much room for tires in the front and you'd be in danger of damaging the rims without enough tire around them. Do a search in the second gen archive. You'll be able to fit the same thing any other normal second gen can, just you have 4 lugs and not 5 like some.
Old Apr 24, 2002 | 05:58 PM
AE Turbo's Avatar
Speed from skill
Those will work.
astrum
24
Nov 15, 2017 08:44 AM
thecody59
14
Jan 23, 2016 11:52 AM
