Apex Seal Failure
Old Feb 23, 2008 | 03:39 AM
3rd Gen Jeremy's Avatar
Apex Seal Failure
So I've got a '93 13REW that I'm rebuilding. I just found the culprit (as I suspected) to be an apex seal.
This is what happened:
I'm open to theory's and comments.
I believe my fuel pump leaned out under high boost and rpm. I've got a Walbro 255lph, PFC, Twinpower, 1680 injectors etc, etc. Running 15 psi on 99'spec twins.
Were the stock apex seals 3-piece?
Old Feb 23, 2008 | 04:17 AM
RETed's Avatar
Yep, detonation...
Chipped "corners" is one of the symptoms.
That largish piece that "broke off" on the other end is a sign of SERIOUS detonation.
Yeah, the original seals should be all 3-piece.
Mazda changed to a 2-piece design somewhere in the mid 90's to late 90's.
If you order apex seals now, they are all 2-piece.
-Ted
Old Feb 23, 2008 | 09:26 AM
cewrx7r1's Avatar
Eye In The Sky
Preventative Measures:
(0) When you tune your engine, do timing in cold weather. Do AFRS in winter and summer to set up Air Temp vs INJ table.
(1) Install a fuel pressure gauge and verify your on boost fuel pressure from time to time.
(2) About twice a year, verify on boost AFRs.
(3) After each gas tank refill, watch at lease one on boost knock levels.
(4) Allow IC temps to stabalize before getting on boost if car had hot soaked parked for a while.
Old Feb 23, 2008 | 12:19 PM
Jason's Avatar
The one
Use Aviation seals next time. No more chipped seals.
Old Feb 24, 2008 | 12:00 AM
Uncle Hungry's Avatar
Talk to me....
Or just do what Chuck said. If you can afford it go ceramics.
Old Feb 24, 2008 | 12:04 AM
well actually I took Blake's advice. I got the Hurley seals while I'm learning to tune. When I get the tune right with the gt35 I'm going to upgrade to, I'm gonna go Ianetti ceramics through Mazdaspeed. I imagine that I'll do that within a year so I want to minimize the risk of detonating real hard and throwing big chunks of seal through the turbos. Once I get comfortable with the tune, I'll put the ceramics in there.
Old Feb 24, 2008 | 08:44 AM
Talk to me....
Good deal, I'm just waiting on the next NRS shipment
Old Feb 25, 2008 | 02:31 PM
So I think the side housing is gouged pretty good on the front rotor. What are my options?
Can I get it resurfaced or do I have to get a whole new piece?
Old Feb 25, 2008 | 07:00 PM
Extra Info: The plate in question has .002 step wear at the corner of the football.
Snook
Oct 8, 2015 10:09 PM
