widest tires!!!??
Old Feb 20, 2008 | 03:41 PM
re-rx7's Avatar
Vp in charge of Girls
widest tires!!!??
What are the widest tires i can put on a 16'' rim in the back? 38 is the offset. trying to go 225
Old Feb 20, 2008 | 03:58 PM
Turbo II's Avatar
It's only Rock and Roll
I run 225/50 on all 4 corners.
Old Feb 20, 2008 | 04:07 PM
re-rx7's Avatar
thanx
Old Feb 20, 2008 | 06:29 PM
Omixeo's Avatar
'89 GTUs
You need to specify was width the wheel is. A 6" wheel and an 8" wheel can run different sized tires.
Anywho, I've got 235/45/17's in the rear on mine. I think I have an 8" wheel.
Old Feb 20, 2008 | 07:31 PM
MaczPayne's Avatar
Mac Attack
for a 16 x 8 wheel, you don't have many choices of tires for the 245/45/16 size. That's why I'll be moving up to 17x9's in the future.
Old Feb 20, 2008 | 07:51 PM
GordiniRX7's Avatar
Cool
Well I got 16x9.5 with 225/50/r16 on mine!
Old Feb 20, 2008 | 10:57 PM
Turbo II's Avatar
I should have said, 225/50/16 is what I run on my stock Turbo II rims which are 16X7 with 40mm offset. If you're using the stock rims on yours you can go up to 245/45/16 in the rear from what I understand. If it's a different rim we need to know the width and offset.
Old Feb 21, 2008 | 09:03 AM
re-rx7's Avatar
no they are 16x7 w/ a 38mm offset. So iam sure they will fit. I will post pics when done.
Old Feb 21, 2008 | 10:36 AM
digitalsolo's Avatar
RX-347
You can fit 275s on the back with the proper width rim. 16x7 would be NOT the proper width.
My 275/40/17 drag radials clear fine on my 17x9.5 +38 TSWs on my stock fender (no rolling) FC. You won't get any more then that without fender work though.
Old Feb 21, 2008 | 11:30 AM
re-rx7's Avatar
I was just wondering if i would rub with the tires i specified.
Old Feb 21, 2008 | 12:39 PM
MaczPayne's Avatar
Mac Attack
You shouldn't rub at all.
Old Feb 21, 2008 | 12:41 PM
re-rx7's Avatar
tHANX FOR THE 411 GUYS!
Old Feb 21, 2008 | 09:51 PM
kil20b's Avatar
Newbie
9.5 wide should be fine.im running that on a 19 inch rim
Old Feb 21, 2008 | 10:38 PM
re-rx7's Avatar
Thanx for all the info!!!!
Old Feb 22, 2008 | 01:13 AM
skatingsamurai's Avatar
**** son
Old Feb 22, 2008 | 01:24 AM
racerlinkfc's Avatar
what about runnning 17x10 in the rear can it be done without rolling fenders? was thinkin ?
Old Feb 22, 2008 | 08:53 AM
re-rx7's Avatar
rx7jocke
72
Jun 17, 2016 03:48 AM
