Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Take a look at my Microtech DIGI 2 Pro Maps: Please give input
Old Apr 21, 2002 | 03:34 PM
Kspurr's Avatar
Sometimes I miss my RX-7s
Hi everyone, I am new to the standalone ecu and microtech world, and
I would appreciate any input that you can give me on my current maps.
I put them in an Excel Spreadsheet and attached it to this post.
I am currently running the DIGI II Pro on a 1987 13b Turbo Motor. It
has been streetported/polished, has 4 stock 550cc injectors, a blitz
blowoff valve, stock hitachi turbo, and 3inch piping to a Weapon R
intake. The car has no emmissions equipment. It was all removed and
plated off (no vacuum hoses, except for the one going to the MAP
sensor. It also has a 2.5 inch downpipe and testpipe going to the
stock Y-pipe and 2 bosal mufflers. The throttle body has had one
modification, with the removal of the top butterfly valves. The boost
has not been modified, and I'm not trying to make maximum power for
racing or anything. I am just trying to get it to be fairly smooth
and reliable for now. Basically, I don't want to damage the engine at
all. (It cost too much to have built.) I know the A/F ratio reading
is narrow band, so I can't really go by it. It just started
fluctuating a lot though, so I'm assuming the increasing temperature
outside may be affecting it. I would appreciate you input/suggestions
on my maps.
Thanks,
Kevin
88 Rx-7 Turbo II Convertible
Old Apr 22, 2002 | 06:24 AM
rxeng's Avatar
HI KSPURR
THOSE MAPS ARE ALL OVER THE SHOP.
HAS THE CAR BEEN TUNED BY SOMEONE OR HAS IT BEEN DONE BY TRIAL AND ERROR?????
I'LL GET YOU A PROGRAM AND PM IT TOO YOU.
IT SHOULD BE A HELL OF A LOT CLOSER AND SHOULD GET IT RUNNING MUCH,MUCH BETTER.
I'LL BE IN TOUCH SOON.
REGARDS
JON
Old Apr 26, 2002 | 07:05 AM
1000HP20B's Avatar
Kspurr,
If John hasnt already sent you a good base map I can help you out as well. The MAP you have is totally wrong and even some of the settings in the setup menu are incorrect. For a start set it to 4 cyl/rotary and zero everything in the TPS menu as you are tuning in MAP mode.
Those old Digi's are pretty primative but I'm sure after you put in the base map John (rxeng) gives you it will be like a different car and provide a good basis for tuning on and go quite well.
Old Apr 26, 2002 | 09:02 AM
Kspurr's Avatar
John actually just pm'd me yesterday saying that he was going to be able to get me some maps. I TRULY APPRECIATE it!!! I've been playing with the computer, and I've got it smoothed out a little, but I know there are little things I'm not going to be able to adjust for, because I started with an inaccurate map.
Old Apr 27, 2002 | 08:37 AM
Anthony Rodrigues's Avatar
Kspurr,
I will be in Dallas over the next two weeks and will be able to provide you with a list of trained MT shops in the US within the next month. I am sure John will be able to sort it for you but if you need any further help PM me and we will sort something out, to get a dyno tune. Make sure you give details about fuel octane, pressure and boost levels.
Good luck
Old Apr 28, 2002 | 10:56 AM
Kspurr's Avatar
Cool, I would love to know of any trained MT shops near me, and I really appreciate the input that I have received on here so far!
Old May 11, 2020 | 04:15 AM
JOHN VERBAN's Avatar
Newbie
Maps
Originally Posted by rxeng
HI KSPURR
REGARDS
JON
PS
hello, can you share any digi2 maps you have?, cheers
jverban@hotmail.com
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
ZacMan
Sep 19, 2015 09:20 PM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
