Power FC PFC Boost Display
Old Apr 21, 2002 | 10:38 AM
PFC Boost Display
What Measurement does the PFC Commander display boost in?
Also, I'm correct in believing that you can display digital numbers in the monitor mode, right?
Thanks
Jeff
Old Apr 21, 2002 | 03:28 PM
spyfish007's Avatar
Yellow Dragon is no more
kg/cm^2
Old Apr 21, 2002 | 08:26 PM
skotx's Avatar
Registered Abuser
Question #2, are you referring to pushing the [Next] button to toggle between graph and numbers?
Old Apr 22, 2002 | 03:09 PM
Oh ok, so its kinda like the afc, being able to toggle between the 2 modes (graph/numeric).... I don't have mine yet, will be about 2 weeks, I'm trying to determine what other gauges I want to budget for.
Thanks for the info.
Old Apr 23, 2002 | 01:02 PM
nocab72's Avatar
03 Cobra Killer
does 1 kg/cm^2 == 14.22psi or 14.7psi
What I am needing to know is when the PFC is set at .95 kg/cm^2 is that 95% of 14.22psi or 95% of 14.7psi, (ie ~13.5psi or ~14psi)
I've been confused on this for a while, maybe someone can straighten me out.
My boost gauge reads closer to 14psi @ .95 kg/cm^2 so I'm guessing 1 kb/cm^2 == 14.7 psi, but my boost gauge is autometer, so it certainly could be reading high...
Thanks!
Old Apr 23, 2002 | 02:17 PM
spyfish007's Avatar
1.0 kg/cm^2 = 14.2 psi of boost. The MAP sensor is known to read lower than most people's boost gauge.
Old Apr 23, 2002 | 02:27 PM
nocab72's Avatar
03 Cobra Killer
Thanks - now I am straight!
K
24seven_dada
20
Nov 10, 2018 12:03 PM
Bauer778
Nov 4, 2015 04:42 PM
RE-Mamamia
Sep 11, 2015 02:13 PM
