Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Recorded some problems during todays drive
Old Feb 8, 2008 | 12:44 AM
WingsofWar's Avatar
The Firestarter
Highway was awesome, of course the idle needed to be turned down and TPS adjusted. As i was going up a hill suddenly lost power, she sounded like she was running on 1 rotor. I try to get on the throttle but was really rough. I turned on the log to get some readings. Im suspecting my trailing coil isnt firing but im not sure here is the log to download. I wont be able to diagnose the problem until tomorrow afternoon, but id like to maybe get a direction based on the log before i do.
Thanks.
http://www.mediamax.com/wingsofwar/H..._52_-_RX7L.PDB
Old Feb 8, 2008 | 05:38 AM
boost_its_what_for_dinner's Avatar
RotoriousRx7
i had that problem a little while back and it was a broke wire in the harness that was sometimes conecting and the not so i rewired from the firewall
but i cant see the log for some reason so thats my 2 cents from exp.
Old Feb 8, 2008 | 09:19 AM
WingsofWar's Avatar
The Firestarter
which wire? was this on the engine harness (passenger) or main harness (driverside)
to see the log your gona have to update your veiwer to version 2.05d
Old Feb 10, 2008 | 03:08 AM
RotoriousRx7
i did update but cant view it for some reasons im not a computer wiz..by no means.
engine harness since thats where the fuel injectors go thru... and there were broken wires halfway to firewall
Old Feb 13, 2008 | 06:33 PM
rx72c's Avatar
Top Answer: 1
You sure its not compression?
Queppa
Nov 18, 2024 03:47 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
gtcd
30
Aug 19, 2015 02:44 AM
joel(PA)
Rotary Drag Racing
Aug 18, 2015 05:56 AM
