Quick Lowering Questions
Old Apr 20, 2002 | 03:47 PM
TurboMike's Avatar
Im in the middle of installing my AGX shocks and Intrax Springs, i have a small problem, the old bump stops won't slide down the agx shocks, i could just dremel out the hole in the bump stop to give it more clearance...any problems with this?? also does the bump stop need to be cut? thanx
Old Apr 20, 2002 | 03:48 PM
TurboMike's Avatar
Pic
Old Apr 20, 2002 | 03:53 PM
kleach18's Avatar
Just Looking Around
I think they will cover it when there is weight on it. When I jack up my car to change the oil it looks like that but when I let it down it matches right up. Its just b/c its not compressed. I think that is what you are talking about. Let me know if I helped at all.
kleach
Old Apr 20, 2002 | 04:02 PM
TurboMike's Avatar
Disregard this post, after looking at the stock shock i realized the bump stop is SUPPOSED to sit that high.
Old Apr 20, 2002 | 04:37 PM
TurboMike's Avatar
how do you torque down the rear shocks?
Old Apr 20, 2002 | 04:40 PM
vosko's Avatar
Just Call Me Terminator!
which part ?
Old Apr 20, 2002 | 04:43 PM
TurboMike's Avatar
the bolt that actually holds the springs and all that other crap on the shock. Damper bolt i think its called in the haynes manual
Old Apr 20, 2002 | 04:50 PM
vosko's Avatar
when turbovr6 and i did my suspension on my TII. we used an impact gun. you can use a regular socket for the bolts on the strut mount. where in nj are you ?
Old Apr 20, 2002 | 04:58 PM
TurboMike's Avatar
i tried that but the shaft on the shock just spins and spings. Im from Barnegat, down near Toms River and Long Beach Island......exit 67 on Parkway. you??
Old Apr 20, 2002 | 05:02 PM
vosko's Avatar
it just keeps spinning...... you put the strut mount on top ? does it spin after you tighten it or it won't tighten and just spins. its not supposed to spin... i'm up in parsippany, north NJ. make sure you checkout the NE forum for events
RotaryBobby
Aug 29, 2015 10:32 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
