Sponsored by: CARiD
New engine prolbem. Well maybe.
Old Apr 20, 2002 | 02:07 PM
1FastT2's Avatar
I just got done installing my new engine. When I say new I mean all new seals, new rotor housing new oil retaining seals & rings, almost everything new. I am confident the engine is built correctly. I also installed a 60-1 turbo, haltech and big FMIC. The car runs great, has a perfect idle except for the lope from the port. It smoked real bad when I first started it up. The smoking went away for the most part but does smoke still a little. The engine now has about 60miles on it. Am I worried about nothing or is this something I should be concerned about? I did use alot of assembly lube and the new downpipe was caked with lube also. Hopefully im just over reacting but I would like your guys input.
Thanks,
Brian
Old Apr 20, 2002 | 03:42 PM
RETed's Avatar
If you're worried, then do a compression check - this is the only thing that's going to confirm is something is wrong.
Seriously, you've got very little miles on the engine.&nbsp I've had engines that smoked up to the first 500 miles!&nbsp I think you're being a bit paranoid at his point...
-Ted
Old Apr 20, 2002 | 03:48 PM
1FastT2's Avatar
Thanks alot, I feel alot better to hear that. Your right I am being paranoid, I find myself pulling over every 5 miles to pop the hood to make sure everything is ok. I should have more confidence in myself.
Old Apr 20, 2002 | 05:22 PM
RETed's Avatar
Paranoid actually is more safe - don't feel bad about it.&nbsp I understand what you mean...I spent a lot of time and money on my first rebuild, and I was super paranoid myself...
-Ted
Old Apr 20, 2002 | 06:50 PM
85RX7GS's Avatar
If you're really worried about it, take it over to KDR.
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
