tubing thickness
Old Jan 30, 2008 | 05:03 PM
frisc's Avatar
improvisor specialist
tubing thickness
is 18 gauge stainless steel thick enough for a turbo manifold? and how thick should mild steel be to make a manifold? Thanks
Old Jan 30, 2008 | 05:32 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
no, not at all
I think your supposto go with sched 40 pipe iirc
Old Jan 30, 2008 | 05:48 PM
frisc's Avatar
Originally Posted by CrackHeadMel
no, not at all
right....anyone else?
Old Jan 30, 2008 | 05:50 PM
13B-RX3's Avatar
7s before paint!!!
I would use at least 16g stainless.
What turbo are you going to hold up with it?
Old Jan 30, 2008 | 05:54 PM
frisc's Avatar
im thinking about a gt42
Old Jan 30, 2008 | 06:00 PM
slo's Avatar
slo
registered user
Rotary headers for NA cars such as the racing beat ones use 1/8th in mild steel pipe, which would be between 10 and 11 gauge, and they don't have a turbo to hold up.
Strength wise 308 SS is weaker and less flexible than mild steel.
A metal supply house will be able to get you whatever pipe (thickness, material etc) you want, you don't have to get it from a shop that sells specifically to the exhaust market.
Old Jan 30, 2008 | 06:51 PM
patman's Avatar
Resident Know-it-All
mine is 16 ga, it has held up fine. however, i have a 1/8 x 2 flatbar bracing the turbo flange to the engine flange on both sides, so that holds up the weight of the turbo.
i would go for schedule 10 pipe, it is around 1/8" thick and you can get bends and stuff cheap from mcmaster. 304 stainless is fine. the next manifold i build will be done that way.
Old Jan 30, 2008 | 08:13 PM
frisc's Avatar
hey thanks for that site it got the pipes i been looking for.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
scissorhands
Oct 8, 2015 01:17 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
