Sponsored by: CARiD
How do you test for fouled plugs?
Old Jan 27, 2008 | 08:35 PM
genxxxracer's Avatar
Question How do you test for fouled plugs?
Just as the title says, is there a way to tell for sure. Everyone always says to replace plugs if there is a chance they could be fouled. Is there a way to tell for sure?
Old Jan 27, 2008 | 09:08 PM
ultimatejay's Avatar
Just pull one of them and inspect. If it is wet or oil fouled then you know they're fouled. I have cleaned foulded plugs before with good luck.
Old Jan 27, 2008 | 11:55 PM
dhays's Avatar
You make that sound easy. I've tried, and they are tough to get to!
Old Jan 28, 2008 | 12:03 AM
sevensix's Avatar
rotor rotor pow.
after doing it 3 or 4 times u'll b a expert
Old Jan 28, 2008 | 12:04 AM
easier with the battery relocated and a front mount intercooler. the back ones top and bottom are still a pita to get to especially with big hands.. so basically if they look clean then just dry them off if they have gas on them and put them back in? ive seen a tester on ebay or autozone that has a light, but that doesnt really indicate if they are working 100% though
Th0m4s
Feb 26, 2019 02:04 AM
efini7
Test Area 51
Sep 4, 2015 02:59 AM
elfking
Aug 19, 2015 09:48 PM
