what kind of amp should i run?
Old Apr 18, 2002 | 06:13 PM
rxspd's Avatar
Hey, im installing 1 PIONEER TS-W254DVC 10" Sub 500 Watt Sub in the spare tire well with a truck box, what wattage amp should i run? How do you wire it for just one sub instead of two??
Thanks, Jason
Old Apr 19, 2002 | 11:00 AM
two 4 ohm voice coils can be run in stereo as a 4 ohm load on two channels, or parallel as a 2 ohm load on one channel. Find a 2 channel amp that is 2 ohm stable and makes 250 watts rms at 0.1 thd into two ohms bridged.
paralleling the voice coils is accomplished by wiring the the positives together and the negatives together, and then connecting them to a single speaker lead. so one 2 conductor cable (1 pos, 1 neg), the pos goes to both pos terminals on the speaker, the neg goes to both neg terminals.
sherff
Feb 24, 2019 12:09 PM
Rotospectre
Mar 28, 2018 03:33 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
