can you push start these cars if there flooded
Old Apr 18, 2002 | 05:49 PM
krazie2insane's Avatar
if so explain my starter is fried
Old Apr 18, 2002 | 06:02 PM
UniqueTII's Avatar
Slow and old
I heard it's possible, but it may take a couple tries.
Old Apr 18, 2002 | 06:15 PM
Audiofight's Avatar
I have push started my 88 SE numerous times. My starter brushes wore out and I had to push start it for a week until they came in at the local parts store.
I would always park at the top of the hill in the parking lot I have to park in. That way I could just shove it down the hill and jump in. Dump second gear and it is all good.
Old Apr 18, 2002 | 06:19 PM
NZConvertible's Avatar
I'm a boost creep...
The unflooding procedure requires you to crank the engine for 5-10sec (WOT, fuel pump off) to clear out the fuel. I doubt you’d be able to push it by hand fast enough, but you might be able to do it by towing the car. Be really careful though or you’ll launch yourself up the tow car’s backside when it fires! A squirt of AFT in the leading plug holes might help too.
But, why don’t you just fix the starter? Even if you unflood it, an engine with a fried starter isn’t much more use than a flooded engine.
Old Apr 18, 2002 | 06:26 PM
cymfc3s's Avatar
I Raise Chickens
push starting a flooded rotary is much easier to start than cranking it because you can get the motor turning faster. I got a motor started that was completely blown except for one chamber.
Old Apr 18, 2002 | 06:52 PM
Ranzo's Avatar
Agreed.
Kyo
Apr 13, 2019 09:24 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
zuesskroph
Aug 13, 2015 06:05 PM
