M2 trailing arms ?'s
Old Apr 18, 2002 | 02:10 PM
Fritz Flynn's Avatar
All out Track Freak!
Just had these put on along with the toe links and its easier to feel the chassis flex and oversteer but I get a thump under hard breaking and accelerating I assume this is the metal on metal side of the trailing arms anyone else notice this?
Old Apr 18, 2002 | 02:31 PM
It's definitely worth a look around under there. I just did the Trailing arms and toe links and then had a bolt come loose between the lower control arm and the bottom of the upright/hub. I'm not sure if I torqued it incorrectly or if the new vibes loosned it up but it caused a clunk under braking or accel. Once it was all tightned up it is just about like stock (noise wise
Alex
Old Apr 18, 2002 | 04:07 PM
artowar2's Avatar
No thump on mine. Try Alex's suggestion and retorque your bolts...
Old Apr 19, 2002 | 07:31 PM
Thanks guys I tightened and thats all it was but I also noticed my right rear rotor is bad anyone have a nice set of rear rotors?
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
GKW
Sep 28, 2015 04:34 PM
