Passenger Window Question (It gets Stuck)
Old Apr 18, 2002 | 01:22 PM
i have a question about my passenger power window i can it goes down fine but when i try to get it to come up it kinda gets stuck and i have to wiggle it back and fourth before it comes up all the way any suggestion on how to fix this!
Old Apr 18, 2002 | 01:28 PM
RETed's Avatar
You need to readjust the alignment...
You need to pull the door skin (and plastic shield) off the door and lower the window a little so ou can adjust the window "tilt" back to front.&nbsp THe tilt alignment is controlled by two (12mm?) bolts that are on the bottom/middle edge of the window glass.&nbsp Loosen the two bolts and tilt the window glass as far forward as possible - retighten bolts.&nbsp Check to see if this works with the door skin back on - this is the most tedious part of the job.&nbsp If it binds a little or make little "cracking noises", you'll need to tilt the window glass back a little at a time...
Good luck!
-Ted
Old Apr 18, 2002 | 01:46 PM
MaxRX7's Avatar
hambre y sueño
you can try cleaning it or replacing the regulator (motor).
either way you'll have to remove the door panel.
cam_7779
Aug 18, 2015 07:48 AM
